| Slant 6 ID https://slantsix.org/forum/viewtopic.php?t=61938 |
Page 2 of 2 |
| Author: | SlantSixDan [ Sat Feb 10, 2018 12:51 am ] |
| Post subject: | Re: Slant 6 ID |
Quote: The 1971 225 is rated at 145 gross HP and 8.4 to 1 compression.
See here and here.
Is this accurate or over rated? |
| Author: | Slant 6 #6 [ Sat Feb 10, 2018 3:54 am ] |
Quote: Quote: The 1971 225 is rated at 145 gross HP and 8.4 to 1 compression.
See here and here.Is this accurate or over rated? Its rated 120 hp at 3600 RPM and 228 ft lbs of torque at 1600 RPM. I think my 265 will.have mote torque than a slant 6 but a slant can be built for more hp. |
| Author: | Slant 6 #6 [ Sat Feb 10, 2018 7:40 pm ] |
Now here is a decision i might end making. Do I swap in the slant 6 into my 1955 Fargo truck with an A833 overdrive. Or go with another flathead i havev a 265 industrial engine. It needs rebuilding. Decisions decisions. |
| Author: | Slant 6 #6 [ Sat Feb 10, 2018 7:43 pm ] |
Hi Dan i am about to buy a bell for the A833 for the slant 6. I also.need a flywheel are the flywheels all the same size and tooth count same too? The bell is from a truck. |
| Page 2 of 2 | All times are UTC-08:00 |
