It is currently Fri Jan 02, 2026 2:44 pm
 Post subject: Slant 6 ID
PostPosted: Fri Feb 09, 2018 5:54 am
Car Model: 1955 Dodge Truck
Hey all bought a 225.
Here is what i was given for its history.
Out of a 1971 Cuda 39k mileage ( highly suspect ), has G 225 R stamped on block deck edge near fuel pump area.
Ive searched like crazy but do figure its a 225 but thats it.
Here are some pics.
Valve train and rockers are filthy but bolts on manifolds undo easy and the outside is fairly clean.
Not sure where its going yet and what it neefs. Last run summer 2017.
 Post subject: Re: Slant 6 ID
PostPosted: Fri Feb 09, 2018 6:02 am
Here are some pics.
ID # 1B369873
casting 2806830-5
0071 AM
PostPosted: Fri Feb 09, 2018 6:03 am
Could not upload pic files my.membership possibly too new.
PostPosted: Fri Feb 09, 2018 10:32 am
So here is the complete number.
R 225 G 4 20 maltese cross symbol ( undersized factory mains .010)
PostPosted: Fri Feb 09, 2018 10:39 am
R 225 G 4 20
I think you mean G 225 R 4 20
G: 1971 model year
225: Engine displacement
R: Passenger car engine
4 20: Engine built on 20 April 1971
Actually, a maltese cross means the engine was built with one or more rod and/or main bearing(s) 0.010" undersize. Which one(s) will be stamped on the crankshaft. If there were a maltese cross with an X behind it, that would mean the engine was built with all the rod bearings and/or all the main bearings.
ID # 1B369873
Where did you find this number?
PostPosted: Fri Feb 09, 2018 2:08 pm
R 225 G 4 20
G: 1971 model year
ID # 1B369873
On the rear right side of the block.
Any idea what it means?
Any idea where this engine was built?
Thanks in advance
PostPosted: Fri Feb 09, 2018 2:45 pm
Your 1B369873 is the last part of a VIN for a 1971 car built at Dodge Main (Hamtramck, Michigan). The complete VIN for a '71 Barracuda would've been along the lines of BL23C1B369873.
No way to tell which engine plant put this engine together. Could've been Trenton, could've been Mound Road, could've been Windsor.
PostPosted: Fri Feb 09, 2018 3:12 pm
Hi Dan and thanx. But definitely a USA built car for the US not Canada.
This car was found in So Cal.and brought to Winnipeg years ago. With 39 k on the odometer which im highly skeptical of...
PostPosted: Fri Feb 09, 2018 3:34 pm
That doesn't make any difference to where the engine (or the car, for that matter) was built. The Auto Pact of 1965 integrated the US and Canadian markets for vehicles and parts; many engines and vehicles destined for first sale in the US were built in Canada.
PostPosted: Fri Feb 09, 2018 3:45 pm
Kool thanx again, will post pics when i am able too..
PostPosted: Fri Feb 09, 2018 6:34 pm
So pulled valve cover, had a look someone didnt like pil
Pulled the oil pan Ive seen dirtier just dont remember
when...lol
Manifold stud bolts undo nice and easy.
Gonna clean her up and maybe run her as
PostPosted: Fri Feb 09, 2018 6:36 pm
Going to need to clean carb and install a kit Holley 1920.
Fuel pump looks newer.
PostPosted: Fri Feb 09, 2018 6:38 pm
Pulled all sparkplugs all carboned and they were newer looking Autolite 66.
Ignition parts rotor points cap wires look good and newer.
The coil looks old and beatup.
PostPosted: Fri Feb 09, 2018 6:39 pm
Will upload pics soon hopefully
PostPosted: Fri Feb 09, 2018 6:42 pm
The 1971 225 is rated at 145 gross HP and 8.4 to 1 compression.
Is this accurate or over rated?
Users browsing this forum: Bing [Bot] and 18 guests
