| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 17 of 91 |
| Author: | madmax/6 [ Mon Jan 17, 2011 11:30 pm ] |
I predict anouther 40lbs by April.Mark |
| Author: | Greg Ondayko [ Wed Jan 19, 2011 9:08 pm ] |
| Post subject: | More Weight Loss 1-19-11 |
Well Mark I beat your prediction by oh 2.5 Months! I got the windshield out -25# Dash removed -25# Other Misc. Items Removed - Sheet metal Braces wiper mounting Reinforcements, Steering column Braces Windshield Gasket / Stainless Trim: -9# So for today I got another 59# out of the front of the car. Running total so far: 256# lighter than 2010.. That will go down a bit when I account for the lexan front and rear glass. it's not here yet. Also I am Going to remove the Rear window... I guess 25#'s there and some more undercoating 2-3#'s there, and the rear bumper and support brakets - Maybe 30+ #'s there? I did some relocation of the Gauges, switches and wiring, Still have to add the tach Back in. I built a real simple AL strap to support the steering column to the Interior Frame.. The One Chrysler gives you is like 3#'s It's built for a mack truck! Pics: Windshield Removed ![]() Dash Removed; Mark should bee happy! ![]() Gauge / Switch Panel Reinstall Pics: ![]() ![]()
| Author: | madmax/6 [ Wed Jan 19, 2011 9:33 pm ] |
I meant 40 more off from TODAY.Steering wheel,turn signal switch and a stock non cut colum look out of place and heavy.I am proud of you.What did the car weigh before you started this diet?Mark |
| Author: | Greg Ondayko [ Thu Jan 20, 2011 10:23 am ] |
Mark, This is the 2010 Weight.. 2575# W/O driver 2775 with Driver. Greg |
| Author: | Dart270 [ Thu Jan 20, 2011 10:28 am ] |
You should be in the 12s now... Nice work. Lou |
| Author: | madmax/6 [ Thu Jan 20, 2011 9:04 pm ] |
According to the Wallace calculater,if you get the car with driver,,,which you will,,,down to 2500lbs,going by your best times and mph, you should go 12.81@ 104.57.YAHOO!!!!Weight removal is like FREE hp.Keep hacking.Mark |
| Author: | terrylittlejohn [ Fri Jan 21, 2011 5:44 am ] |
do me one favour, don`t remove that grill to save weight, it the coolest front on a valaint. |
| Author: | Greg Ondayko [ Fri Jan 21, 2011 8:49 am ] |
| Post subject: | Back Glass removed - 1-20-11 |
Thanks for the predictions Mark, I am not sure however that you calculations account for the future gear change form 4.30 to 4.56 and the aero Stuff / Stance. Terry, I might Experiment with covering it, but i'ts pretty light as it is now. The grille as it is now ismade of all thin sheet Aluminum and a whole bunch of holes already punched in it. I got the back Window removed, ready for some lexan to go in there. Rear Glass -17# Rear Glass Gasket, Trim, Clips etc. - 5# Running total weight loss: Since November 2010 278# Greg |
| Author: | Dart270 [ Fri Jan 21, 2011 9:51 am ] |
You are getting to Possum Parker weight range, and engine performance appears similar, esp with a little more tuning. It'll be interesting to see you run Gary Bruner or Parker this year... Lou |
| Author: | Greg Ondayko [ Fri Jan 21, 2011 11:59 am ] |
Maybe I'll Just have to go Possum huntin and get me a Bagel bamboolzer too! Greg |
| Author: | Rick Covalt [ Fri Jan 21, 2011 1:54 pm ] |
| Post subject: | Bamboozaler |
I have heard much talk about the Bagel bamboozaler, but I have yet to see one in captivity. If you locate one or see one in the wild will you please take a picture of it for us! Rick |
| Author: | Greg Ondayko [ Fri Jan 21, 2011 5:18 pm ] |
| Post subject: | Rear Lexan Install 1-21-11 |
Well I got the Lexan rear window in - The Sheet Blank Arrived today and I wased no time getting it installed. Mason Dixon opening day / TNT is less than 2 months away! Here are Some Pics: I began By transferring the outer shape of the rear window to Cardboard. Lots of compound Curves here that are tough to match on flat sheet. ![]() Bye Bye Rear Glass / Gasket. ![]() Sheet Blank - Gave me a few inches extra on all sides. ![]() Template Transferred to lexan sheet - Lots of cutting, roughing in and test fits to get this correct.. I cant imagine doing this on a 64-66 Barracuda. ![]() Install Complete. Lexan only adds 6# back to the car! YAY! ![]() ![]() ![]() Lexan Rear Glass +6# Total Weight Loss since November 2010 Now @ 272# Greg |
| Author: | Dart270 [ Sat Jan 22, 2011 7:45 am ] |
Good work. That is a tedious job. Lou |
| Author: | Greg Ondayko [ Sun Jan 23, 2011 4:31 pm ] |
| Post subject: | Guzzi Stylin' 1-23-11 |
Well Another update - We had a snow day on Friday so I had a 3 Day workin on Ruster weekend. I made a Support bar for the parking brake - It used to conncet to the dash which is gone.. ![]() I made A "pocket" for my Junk that used to reside in the Glove box. Used an old Pant leg and basically riveted it to the floor. I got the 5 point racing belts installed! ![]() ![]() ![]() Fabbed up some grille Coverings: Terry, The grille is not gone, just Covered - They are easily removed with 2 Bolts. ![]() ![]() ![]() I am also Thinking of going with the '67 Center Grille piece if I can find one ![]() Greg |
| Author: | slantzilla [ Sun Jan 23, 2011 4:39 pm ] |
Quote: Maybe I'll Just have to go Possum huntin and get me a Bagel bamboolzer too!
How'd I get drug into this? Greg I have no idea what a Bagel Bamboozler is either. |
| Page 17 of 91 | All times are UTC-07:00 |
