It is currently Sat Nov 28, 2026 10:38 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Dec 10, 2004 12:30 pm
I am unsure of the alt amperage. However, if the replacement part I looked up for a '96 Intrepid at NAPA Online is correct, it is a 90 amp alternator (Item#: BSAAL6508N). Note: This particular alt would require finding and installing a V-belt pulley, as it comes ready for a 6-groove serpentine pulley.
What I do know is my charging system 'behaves' much better with this alt than it ever did in the past with the factory 78 amp or 100 amp alternators (and some upgraded wiring); particularly at rpm's below 800-900. My headlights no longer dim at idle (in gear), and my turn signals do not slow down at idle.
The mounting points on this particular model do take some thinking to make work. It is likely there is another alt with mounting points that would be easier to adapt. I simply had free access to any and all parts from this particular Intrepid (wrecked--a friend owned it).
<img src='http://img.villagephotos.com/p/2004-10/860264/MultiBracketInstalled(sm).jpg' width=320 height=240 >
-S/6
PostPosted: Fri Dec 10, 2004 12:50 pm
That looks like the exact same ND 90amp alt I am running on the Duster... If it is, it will practically drop onto the stock alt location with only very minor modifications to the lower bracket (and of course you need to find a v-belt pulley). See description about a dozen posts back.
D/W
If it ain't broke, fix it!
