It is currently Sat Nov 21, 2026 6:34 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Nov 10, 2005 7:36 pm
Autoline rebuild
I believe we've identified the problem.
PostPosted: Thu Nov 10, 2005 8:08 pm
Condensor
PostPosted: Thu Nov 10, 2005 8:09 pm
Update:
Replaced fuel pump with Crappy Tire Special, raised float level, no improvement. Still cutting out after 5 or so minutes of hard driving. Kept the car to a stumble all the way home, parked it, WOT in gear til it stumbled, shut it off. Whipped out the plugs, all are reading lean with a light dusting of white powder. Compression test: 135 all the way across.
I realise that the carb is lean, but I have a #65 jet in there. The only thing I can attribute the lean mix to is the throttle shaft bushings, they have slightly perceptible play in them, no other leaks that I can find. I have been trying to get a proper working carburetor on this engine for at least a year now. Propane, carb kleen sprayed at the intake mfld gasket all day does not change the idle. PCV looks fine. I cant understand it. There has to be more to enriching the main circuit than just swapping the jet, it has made very little difference to mine and most people are running a #62 jet. Being that as it may be, I still dont think the carb is the direct reason for this stumbling, as the car pulls smooth and strong for the first few minutes, the stumbling seems to come when the engine reaches a certain temperature. I can drive for a fair distance longer if I take it easy, maybe all day, I dont know. But as soon as I start hammering on it or take it out on the highway, the stumble comes back. There is no more backfire, but hit the gas and it will stumble.
I suspect there must be a crack between some of the exhaust and intake valves, my cousin's Pony did this same thing albeit more severe and this is what he found. But I dont know, Im exhausted. Ive thrown everything Ive got at this thing and made no difference.
Last edited by steponmebbbboom on Thu Nov 10, 2005 8:12 pm, edited 1 time in total.
PostPosted: Thu Nov 10, 2005 8:10 pm
Condensor
Tomorrow I will throw on a new coil and ignition kit, after that I am out of ideas. Thanks...
PostPosted: Thu Nov 10, 2005 8:16 pm
Run it without the gas cap.
The tank might not be venting.
PostPosted: Thu Nov 10, 2005 8:28 pm
No. Slightly-perceptible play here will not cause anywhere near the severe symptoms you're experiencing. I think your carb's power valve and/or metering block are FUBAR. Welcome to the Wonderful World of Wemanufactured CarbuWeters.
Send me a PM.
Choke compensates for screwed-up carburetor
Seriously doubt.
my cousin's Pony
I'm assuming you mean Mustang, i.e., Ford. Of course it broke, it's a Ford. You own a Mopar.
I like Sandy's suggestion to check the distributor condenser if you're not yet running electronic. But barring that, I think it's your carb.
PostPosted: Thu Nov 10, 2005 8:39 pm
Dan, I forgot to mention that the choke has been wide open throughout this evening's adventures, I have never allowed the engine to cool. These symptoms started last night, there was no lead-in to this problem and my fuel filter hasnt let anything into the carb, the bowl was clean. Still not ruling out the metering block completely. I have not looked at the power valve, if that is not one and the same with the accelerator pump, that is.
Youll please excuse my ignorant tone, mental exhaustion here and there's no booze in the house.
I also just ran out and checked my points, they show no signs of burning/metal transfer.
Pony... it was a Hyundai Pony. Great little car it was except for the weak head design and poor rust resistance, but they never washed it once, I have to be fair.
PostPosted: Thu Nov 10, 2005 8:53 pm
Not the same. Different.
Those shatzboxes are much worse than Fords.
PostPosted: Thu Nov 10, 2005 9:22 pm
Pulled the gas cap, no "shoop" sound, tank is filled to the top with Pioneer 89 octane. It's a good thought though, Ill try driving with the cap off tomorrow.
PostPosted: Thu Nov 10, 2005 9:32 pm
It's not gonna be your gas tank failing to vent; leave the cap on. And while this isn't a direct cause of your problem, try shopping for gas at someplace other than Pioneer. They, like Ultramar, water down their gasoline with alcohol.
Currently Esso produces the best gasoline in Ontario.
PostPosted: Thu Nov 10, 2005 9:49 pm
Really? I thought their gasoline had the highest sulfur content of all the major brands. What do you think of Sunoco?
PostPosted: Thu Nov 10, 2005 11:36 pm
Maybe, maybe not.............
But since it's such an easy check might as well to cross it off the list.
Plus, you'd feel really really stupid if it is the problem and you decide not to check it..............
PostPosted: Fri Nov 11, 2005 4:08 am
With all you have gone thru, here is a sugestion, that will take a little work. Get a metal can, boat gas tank, or something similar, and a cheap electric fuel pump. Hook the electric fuel pump to the container, and run a line to the carb. Put some fuel in the container, and have a friend hold the container in front seat, while you drive. Now see what happens. It you still have a problem, it is not the gas tank/sock/pickup, fuel lines, or pump. It could still be the carb, But if you have changed carbs and still have the exact same problem, that is not likely.
PostPosted: Fri Nov 11, 2005 4:16 am
Well now that Ive adjusted the valves and no longer have a backfire, I am starting to think that it's ignition related. When I did a fuel pump test and saw that the output pressure did not fluctuate as the car was stumbling, I cant imagine that the flow output under these conditions would be the problem, it could not possibly maintain 4 lbs of pressure if the float has dropped and there is no fuel left in the line. I checked the needle valve, it is in good shape and isnt stuck.
PostPosted: Fri Nov 11, 2005 7:27 am
Used to. As of December '03, though, all their refineries produce very-low-sulfur motor fuels, the lowest in the market, as a matter of fact.
I don't buy it, it's watered down with alcohol—no matter how much PR spin they apply to that practice, I avoid gasohol whenever and wherever I can. I don't like getting less (energy, mileage) for my money.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
