It is currently Sat May 09, 2026 10:09 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Jun 28, 2021 9:38 pm
The one thing to check engine off full throttle , if things are to far off metering rod can go to high and come out of jet. If that should happen carb will not return to curb idle.
PostPosted: Mon Jun 28, 2021 9:55 pm
There is a gap, room for movement between the rich and lean piston stops, the step-up spring handles this. It is a tuneable part,modern day eledbrock springs will work.
PostPosted: Thu Aug 05, 2021 11:04 am
PostPosted: Thu Aug 05, 2021 11:12 am
That white 0.010 shim, if that was in place during adjustment ,that extra gap would allow the vaccum piston,under high vaccum to pull rods down an extra .010 Leaner.
