| Turbo Toad https://slantsix.org/forum/viewtopic.php?t=45802 |
Page 3 of 9 |
| Author: | Turbo Toad [ Wed Mar 21, 2012 9:40 pm ] |
Kevin the starter is a mid 90s Durango mini the neg terminal is different it has a stab in style connector I just used a butt splice on the end and it slides over the post ill post some pics with the new Turbo and waste gate attached tomorrow Aaron |
| Author: | Turbo Toad [ Thu Mar 22, 2012 6:10 pm ] |
Here a couple mock up pics of the new setup ![]()
| Author: | Shaker223 [ Fri Mar 23, 2012 6:22 am ] |
LOOKING GOOD!! |
| Author: | Volare4life [ Fri Mar 23, 2012 7:51 am ] |
Looks great, what did you use to make the manifold ?? BTW SOOOOOOO jealous of that heated intake lol !!!!! -Mike |
| Author: | Dart270 [ Fri Mar 23, 2012 10:38 am ] |
Sweet work. Lou |
| Author: | Turbo Toad [ Fri Mar 23, 2012 11:58 am ] |
Quote: Looks great, what did you use to make the manifold ?? BTW SOOOOOOO jealous of that heated intake lol !!!!!
-Mike Mike I used 304 stainless steel butt weld ells there about 3/16 thick. Also the flanges are SS as is the 6 to 1 merge collector. That intake is a nice piece I traded a new set of headers for it. I love the fact it has the bosses at the end of the runners so if in the future I decide to go EFI I could. Thanks Aaron |
| Author: | olafla [ Sat Mar 24, 2012 9:48 pm ] |
Nice work, Aaron. Could you please go through this thread from the start, and update the photo links, if you still have the pics? Olaf |
| Author: | Turbo Toad [ Sat Mar 24, 2012 10:08 pm ] |
Quote: Nice work, Aaron.
Olaf ill work on it in the next couple days thanks for the interestCould you please go through this thread from the start, and update the photo links, if you still have the pics? Olaf Aaron |
| Author: | slantzilla [ Sun Mar 25, 2012 5:16 am ] |
Very nice. |
| Author: | stop the beast [ Tue Mar 27, 2012 3:42 pm ] |
Looking good! |
| Author: | 1974duster kev [ Wed Mar 28, 2012 2:54 pm ] |
I may have missed this info, but what size turbo is that? cool a durango starter hmmm is that about the size of a mini starter or those mini's still smaller than that? Kev |
| Author: | Turbo Toad [ Wed Mar 28, 2012 4:07 pm ] |
Kevin the Turbo is a turbinetics T60-1 60mm cold side.68mm exhaust side as for the mini looks like one I had on a big block 67 cuda in the 90's our then the different negative connects Here's a couple pics Im installing some frame connector there all tacked in and just awaiting the final welding ![]()
| Author: | Turbo Toad [ Sun May 06, 2012 12:17 am ] |
| Post subject: | 5/6/2012 |
Here's a couple pics of the new setup with the motor and transmission installed ![]() ![]() I hoping by the end of next week I should be ready to fire it back up Aaron |
| Author: | Dan-o [ Sun May 06, 2012 6:25 am ] |
Very cool. Where did you get the flanges to build the exhaust? |
| Author: | Turbo Toad [ Wed May 09, 2012 12:58 am ] |
Dan O the flanges I bought of ebag there's a guy that sells them but every now and then you can find a pair of them in a auction and there Alot cheaper I think I paid around 20 bucks for stainless ones which the guy I'm referring about sells the stainless ones for around 90 bucks The header cost me around $400 bucks to make but I'd have to say probably about 60 hours to fab up and weld it was a very time consuming task but I'd I'm very happy with how it turned out I'm about ready to start it back up I was trying to flush the gas tank out two days ago and my fuel pump took a $#!+ on me so I had to order a new one but it should be here by the end of the week which isn't a problem it's given me some time to plumb in my water lines for the turbo and the intake also the trans to the trans cooler I'll post some updates this weekend Aaron |
| Page 3 of 9 | All times are UTC-07:00 |
