It is currently Wed Oct 14, 2026 9:46 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Apr 05, 2012 2:48 pm
I can't do that because there is no tab there.
Um...then what is this photo of, please:
PostPosted: Thu Apr 05, 2012 3:23 pm
that's on the drivers side and i thought you were asking me to make a mark on the tab on the other side and there is not tab on the other side..
It was a misunderstanding on my part sorry for the inconvenience have a good weekend
PostPosted: Thu Apr 05, 2012 4:27 pm
Hey Dan thanks again for the reply
Now I just need to figure out how to make piston stop
You can make one if you want, but you had already stated that you had removed valve cover and correctly 'found' TDC by wiggling the rocker arms. The stop isnt need @ this point, all is needed is a mark on the pulley @ the TDC location of the timing tab...
MRO....
PostPosted: Thu Apr 05, 2012 4:28 pm
So there is absolutely no difference between the relevant parts of your car as it exists and the relevant parts of your car as I described it. Very good. This means you should have no trouble following the simple step-by-step instructions that have been provided.
PostPosted: Thu Apr 05, 2012 4:48 pm
You can make one if you want, but you had already stated that you had removed valve cover and correctly 'found' TDC by wiggling the rocker arms. The stop isn't need @ this point, all is needed is a mark on the pulley @ the TDC location of the timing tab...
thank you
i wish i had owned one of these and had been working on them for years like many others if so i would be much smarter. but i was able to get a new mark on the pulley and got it timed and running good. Now i just need to ( for now) take care of the carb issues and all will be well until the next problem arises.
I was also able to find a chart that says the engine is a 2463430 225 1960-1967 (RG-series) and narrowing it down even more with this number B 225 5 20 and i believe it is a 1966 engine
thanks everybody now off to lurk the search function
PostPosted: Thu Apr 05, 2012 6:09 pm
That is excellent news!
There are but 2 rules to the search function:
1: Use it often!
2: See rule #1.
~THOR~
PostPosted: Fri Apr 06, 2012 4:56 am
i do use the search function a lot but while some info is of general idea and use many of it is geared to a specific problem a person is having.
Either way I do thank you guys very very much for all your help and it is much appreciated
