It is currently Fri Nov 20, 2026 10:47 am
Post new topic  Reply to topic  [ 62 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sun Jan 04, 2015 6:53 pm
pulled the front seats out,,
bunch of stuff under there
https://www.flickr.com/photos/13718356@ ... 801277533/
top value and s&h green stamps ,, remember those
Beemans gum wrapper
lots of pull tabs and hair pins
A Standard Oil Credit card, for Joan Burroughs, name on the title as the original owner
A pack of Indiana University matches
coins:
quarters: 1969 and 1972
dimes: 1974, 1971,1968,1965
nickel: 1969
penny: 1959,1963,1964,1964,1965,1966,1967,1968,1968,1970
a "Take a Slake Break" button
I put that in google to see what would come up,
apparently that was a Falstaff Beer slogan back in the 60's
http://www.ebay.com.au/itm/1-inch-1963- ... 1095100196
https://www.flickr.com/photos/13718356@ ... 717286548/
PostPosted: Mon Jan 05, 2015 4:39 pm
Poser
Okay, I wondered where all this stuff ended up.
Zilla was talking to me just the other day and said he was missing some hair pins.
I have been missing some vintage coins and I know that you DID NOT list the missing silver dollars.
Anything Falstaff related has to belong to Mater - this is what he buys in KY. He has to relocate to the Fatherland every so often to get good beer.
The pull tabs prolly belong to Sandy - most likely some sort of vintage red ale from the great white north.
DT, please return these at once because of the sentimental value.
PostPosted: Mon Jan 05, 2015 4:59 pm
Red ale only comes in bottles.....
Are pull tabs not a kind of beer parlour lottery game?
PostPosted: Mon Feb 09, 2015 7:00 pm
https://www.flickr.com/photos/13718356@ ... 670942946/
got the 68 barracuda off jack stands and back on the ground this past weekend. 8.75 in the rear,, new springs, shackels, shocks,, front end suspension and steering all re built,, 4 wheel disks, and new brake lines,, still need to bleed the brakes,,
the wheels on the car are the OE rims from the 83 D-150,, the tires on the front rims are actually the 1983 OE tires,, trust me the tires are just to roll the car around on,, although I plan to run the car on the steel wheels for awhile anyway..
the block and head are back from the machine shop,had them hot tanked, not going to do a lot to this motor,, staying with stock valves,, but I did have the head cut .080, I am going to pull the valves and do some port clean up and change out the stem seals,, for the case, I will re build the oil pump, put in a new timing chain, have the cam ground, the cranking compression was not bad,, 120 on all cylinders,, the OE pistons, rings and bearings are all going back in..
I'll build a better motor later,, for now just want to get the car powered.
 Post subject: Lol...
PostPosted: Mon Feb 09, 2015 7:13 pm
Only if you are Bob and Doug McKenzie playing Beer Hunter...eh?
Pics look good, should be a good runner.
PostPosted: Sun May 03, 2015 5:27 am
the motor is re assembled and back in,,
https://www.flickr.com/photos/13718356@ ... 325999761/
took the engine apart, block and head hot tanked, it had a lot of internal sludge and crud.
for the head, cut .080, mild porting, oe valves, valve job, new valve seals and newer springs.
for the case, reused OE pistons, rings and all bearings, new timing chain and re ground cam, new water pump,new head gasket and all seals replaced. Newer fuel pump, oil pump is the OE pump from the 83 D150,
progress :D
PostPosted: Sat Jun 13, 2015 11:43 am
I saw a post by Rick Covalt, mentioning using a power steering bracket and the OE alternator adjusting arm to left side low mount a Denso alternator on a slant.
as Rick mentioned, welded washers on the power steering bracket 'drop in' holes, to secure the Denso body,
A stock slant alt adjusting bracket fits nicely to the 12:00 water pump bolt,
I did some calculations for the belt,
length calculates to 37.78 in, so it appears to be a C38 V belt
http://www.slantsix.org/forum/viewtopic.php?t=57821
the clerks at AZ were completely lost when I asked for a C38 V belt,
moved over to NAPA, they could get one, but wanted $28 and change with no return,, went to the internet, got one being shipped to me from vbeltsupply.com for 21.00,, actually for the 21, I have a 37 and 38 inch ordered,
as I think I can swing the alternator up a bit closer and use a C37.
Got the Denso from the local pull a part,, off a Dodge 1500, checks out good, 90 amp.
here are photos:
https://www.flickr.com/photos/13718356@ ... 4109045568
the alt belt in the photos was cut to 38 inches inside length and tapped together.
PostPosted: Sun Jun 14, 2015 3:57 am
Nice work. Looks familiar, only I used a parts store chevy alternator top bracket with a couple of bends.
Progress is good!
PostPosted: Tue Jul 07, 2015 4:26 pm
progress,,
https://www.flickr.com/photos/13718356@ ... 5572674402
electric: radiator fan, water pump, line lock, all running through relays and wired through dash mounted trigger switches for each...
fan is a pull apart 90 Neon
water pump is a used Moroso, bought during the 07 market crash
line lock is a cheapo Summitt
additional switch is for a HEI kill switch
PostPosted: Sun Sep 20, 2015 11:47 am
ready for Clay City :D
https://www.youtube.com/watch?v=0lIEJm6rdiE
PostPosted: Mon Sep 21, 2015 8:37 am
Sweet! Congrats, John. Look forward to meeting the car and you at Clay City.
PostPosted: Mon Oct 05, 2015 5:41 pm
https://www.youtube.com/watch?v=rHkRM_ZRrAc
this video was shot Friday Sept 25th,
Slantzilla was the eye behind the camera,,
if it was not for the wash out at Clay City,,,
so in the mean time, been working to get this car where it will pass a NHRA inspection, going to run it at a test and tune at Lucas Oil Raceway , near West side of Indy..
shooting for Oct 14th,,
PostPosted: Mon Oct 05, 2015 5:58 pm
Suburban burnouts......lookout kids~
PostPosted: Mon Oct 05, 2015 8:47 pm
What about the donuts on the cul-de-sac?
:wink:
PostPosted: Tue Oct 06, 2015 5:57 am
NO DOGS WERE HARMED DURING THE FILMING OF THIS EPISODE. THE CAT GOT SICK AND SOMEBODY SHOT A DUCK BUT THAT'S ABOUT IT."
— The Simpsons, "Dog of Death"
....like what is shown in the current Dodge Bro's TV commercial.... :roll:
