It is currently Fri Oct 23, 2026 8:36 pm
Post new topic  Reply to topic  [ 231 posts ]  Go to page Previous 1 2 3 4 5 … 16 Next
PostPosted: Sat Feb 28, 2015 5:58 pm
Car Model: 1964 Valiant
I hope that there is a 2nd run in the future ! These are cool but I don't think I can do it right now.
With these as well as Dutra Duals I'd like a boss that would enable attaching copper or stainless tubes for a carb heat box on EOM manifolds, or O2 sensors. The ports could be on the underside to retain the stock appearance. These manifolds are sweet as is.
 Post subject: heat for carbs
PostPosted: Sat Feb 28, 2015 6:46 pm
what are those bolt holes in the hyper pack manifolds for, the ones about mid-way along the manifolds, on the front sides. I was thinking the same thing, maybe mount a heat box on those somehow, but make it free floating.
You can always drill/tap for O2 sensors, but I'd likely put in the down pipes, just before the collector (if there is one).
brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Feb 28, 2015 7:14 pm
They are where the original intake and exhaust manifolds were bolted together. You will likely get some heat right off of the manifolds if you are running anything other than the long Hyperpak. But you could fab up some kind of shield to direct heat up under the carb area.
It was also mentioned about the D/S Alternator. I do have mine on the D/S. It is the full size alternator and it still has probably 3 or 4 inches of room between the manifold and the Alternator.
Rick
 Post subject: heat
PostPosted: Mon Mar 02, 2015 10:55 am
Rick,
Yes, I have a heat shield as well, there is plenty of heat in that area once she warms up.
I think your right, maybe just a deflector mounted to the front manifold that guides heat toward the intake heat box, doesn't have to touch it per se. That should be enough. Basically an inverted funnel made of sheet metal should work - concentrate the convective heat to the heat box area. Maybe coat the manifolds black to enhance radiative heat (emissivity) as well.
I'm sure once I have the hyper packs, I'll work on a design and share with all. I'm into aesthetics, so it'll be nice looking as well as functional.
Brian
 Post subject: PS clearance
PostPosted: Mon Mar 02, 2015 10:59 am
It seems like with choices of pumps, Saginaw, Thompson, Federal; how far out the belt allows it to go; and PS bracket modifications, there should be a at least a few ways to clear the front manifold, if they already don't clear it.
brian
PostPosted: Mon Mar 02, 2015 11:03 am
The GM style pumps appear to be skinnier front to back, maybe that's a fix as well...
http://www.summitracing.com/parts/brg-800310/overview/
Brian
 Post subject: more compact....
PostPosted: Mon Mar 02, 2015 11:12 am
This style appears to have a pretty compact body...because it uses a remote reservoir. Slant sixers have that driver side canyon of space to work with...
http://www.summitracing.com/parts/aaf-a ... dia/images
http://www.summitracing.com/parts/sum-340202/overview/
brian
PostPosted: Wed Mar 04, 2015 6:24 am
Sign me up! PM sent!
Really wishing I hadn't sold my Hyper Pak intake and new 390 carb a few months back! I guess I'm in the market for another HP intake manifold too...
PostPosted: Thu Mar 05, 2015 7:30 am
I have had several e-mails back and forth with Steve Magnante and he was very excited to hear about the manifolds and offered to pass the word around in his circles. He still contributes to Mopar Muscle, Car Craft ...etc and he may be able help with a little bit of "advertising". I believe there will some more folks come forward as the project progresses. I will keep everyone posted as the Summer moves on! Slow and steady wins the race.
Rick
PostPosted: Thu Mar 05, 2015 8:58 am
Sounds great, Rick. Steve is a wonderful guy. Need to catch up with again sometime.
Cheers,
PostPosted: Sat Mar 07, 2015 9:55 am
Rick
That's awesome! I bet He still regrets getting rid of those white cars!
PostPosted: Sat Mar 07, 2015 1:56 pm
Yes he checks in here from time to time. I told him one of his altered wheelbase darts with a Hilborn injected Slant 6 5 speed would be cool! :lol: :lol:
I have a new e-mail address for the project, and I need to get him some pictures and then he will take care of the rest.
Rick
PostPosted: Sat Mar 07, 2015 2:44 pm
Is Steve still up in the Northeast? See if you can get him to Mason-Dixon
PostPosted: Sat Mar 07, 2015 4:49 pm
I dont know for sure, but there is a 508 Area code on his website.. Maybe an office or old cell # from Connecticut... but it seems feasible that he could also be in LA suburbs also.
PostPosted: Sat Mar 07, 2015 4:56 pm
I'm pretty sure he is in Mass.
I will invite him down to Mason Dixon
Users browsing this forum: Ahrefs [Bot] and 15 guests
