It is currently Mon Nov 16, 2026 11:37 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Sat Aug 02, 2025 11:33 am
Site Admin
dxf and dwg files should be unloadable now. I'm not sure how this works because I don't use the feature but the file types are allowed.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Tue Aug 12, 2025 8:06 pm
Thanks Chuck. I will check it out when I have the computer and access to some files.
PostPosted: Mon Sep 29, 2025 8:19 am
Car Model: Dodge D-150
Hi guys, I’m wondering if I could get CAD file for the valve cover load gasket I think it is, we’ll not really a gasket but to put on your valve cover so that it puts an even amount of pressure everywhere, thanks, and what kind of gasket should I use can I use high heat grey gasket maker?
PostPosted: Fri Dec 05, 2025 1:24 pm
Car Model: 1983 d150 a833 vin m
I gave up with trying to get a valve cover to seal using a gasket and not distort the sheet metal. Any of the utra rtvs. Just make sure the surfaces are clean and oil free like you would if painting. Apply a bead on both surfaces and assemble as fast as you can fully seating but not striping the bolts and let sit for 2 days. If you have to remove he cover you will need to heat the area with a torch to get the rtv to break its bond.
I may be slow,but I"m ahead of you.
