valve cover gasket cad file?
https://slantsix.org/forum/viewtopic.php?t=67319
Page 3 of 3
Author:  Chuck [ Sat Aug 02, 2025 11:33 am ]
Post subject:  Re: valve cover gasket cad file?
dxf and dwg files should be unloadable now. I'm not sure how this works because I don't use the feature but the file types are allowed.
Author:  Greg Ondayko [ Tue Aug 12, 2025 8:06 pm ]
Thanks Chuck. I will check it out when I have the computer and access to some files.
Author:  Daniel F [ Mon Sep 29, 2025 8:19 am ]
Hi guys, I’m wondering if I could get CAD file for the valve cover load gasket I think it is, we’ll not really a gasket but to put on your valve cover so that it puts an even amount of pressure everywhere, thanks, and what kind of gasket should I use can I use high heat grey gasket maker?
Author:  frank79912 [ Fri Dec 05, 2025 1:24 pm ]
I gave up with trying to get a valve cover to seal using a gasket and not distort the sheet metal. Any of the utra rtvs. Just make sure the surfaces are clean and oil free like you would if painting. Apply a bead on both surfaces and assemble as fast as you can fully seating but not striping the bolts and let sit for 2 days. If you have to remove he cover you will need to heat the area with a torch to get the rtv to break its bond.
Page 3 of 3 All times are UTC-07:00
