| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 26 of 90 |
| Author: | madmax/6 [ Sat May 21, 2011 9:43 pm ] |
Going out first round sucks,I know cause I do it alot.Getting a GREAT time slip does lessen the pain,your doing great.Better elevation,shocks,and anouther 25lbs out ofthe car and I bet you will bee sub 12.50.You have done great with your car and I know you will do even better.Guzzi Mark |
| Author: | chazc [ Wed May 25, 2011 3:55 pm ] |
great buildup! whats your camshaft specs? |
| Author: | Greg Ondayko [ Thu May 26, 2011 6:44 am ] |
Quote: great buildup! whats your camshaft specs?
Hello, Look near the bottom of this page http://www.slantsix.org/forum/viewtopic ... sc&start=0- Pic of the cam card is in there. Greg |
| Author: | madmax/6 [ Thu May 26, 2011 10:23 pm ] |
After re looking at pics.Didnt remember you starting with such a turd.You have done wonders.Still a very fast /6 cool turd.Hopeing you keep it the way it is ,Minus a few more pounds.Guzzi Mark |
| Author: | Greg Ondayko [ Tue May 31, 2011 10:27 am ] |
| Post subject: | Misc. Update 5-31-11 |
Thanks Mark It's Still a huge turd.... But I like it in the turd-like state! Well I had a Flat tire(front) when I went up to stage for the Gambler's race on Saturday after the Slant 6 Eliminations were done. So I had to find some other tires and wheels So I could run the race on sunday. Brian mimken had Some Large Bolt pattern Rallyes for sale That Ron Hamby Bought... Ron Hamby was gracious enough to let me borrow 2 wheels / tires to thow on ruster for sunday's race. I got back home and ordered 2 new front runners. My old Hoosiers were trashed and totally worn in the center.. I Probably had too much air pressure in them. Also I Have to relocate the Tranny cooler - Oh hotter days it's not cooling like it did when I Had that open grille. It will be relocated under the Passenger side Of the car. Tire / Wheel Front runner Pics: The Unmounted Moroso DS-2's Weigh 12# Versus the 9.5# of the Worn Hoosisers (they Were down to the Cords when taken off) Total Weight of the New DS-2's Mounted are 23# ![]() ![]() ![]() ![]() ![]() ![]() Greg |
| Author: | Greg Ondayko [ Fri Jun 03, 2011 8:45 am ] |
| Post subject: | Test n Tune 6-2-11 |
Well After Getting The DS-2's balanced and relocating the Tranny Cooler, I headed to the track yesterday for some Runs. Weather Was cool, and humidity was low.. Rare for this time of year in PA, but it was good. I ran another 12.88 @ 105.1 (matching my best from mason-Dixon A few weeks ago. A 13.00 off the trailer was pretty good too. I tried The 3 way adjustable Front shocks on loan from Rick Covalt. (thanks Rick!) 90-10's for runs 3, and 4, and 80-20's for runs 5-6. the 60' Times slowed anywhere from .002~.005 With these shocks versus the Stock Oil Type front shocks. Also I found a new converter to try. Just have to install it. Time Slips: (Runs 1,2,3 On top, 4,5,6 On bottom) ![]() Greg |
| Author: | 1974duster kev [ Fri Jun 03, 2011 1:02 pm ] |
Sweet! that thing scoots down the track in a hurry. You must hook good the 60ft looking nice. Kev |
| Author: | Greg Ondayko [ Wed Jun 22, 2011 2:38 pm ] |
| Post subject: | More Cutting And trimming |
Quote: I can probably find 100 More #'s by The end of summer. I managed to find 10# toward my summer goal of getting 100# out by the end of summer 2011. I took something off a while back that was 1# and I took out 9# today. So now ruster is 327.5 # lighter than nov. 2010. RF door Lost alot of weight. RF Cowl heater box area is lighter RF fender Lost some unneeded bracing. LF&RF inner wheel house got lightened a bit. (I GOT WINDOWS MARK!) Other junk I got done - Planning cold air intake system, - Planning Rear Spring Rework, Trying Looser converters (when time / $ allows) Even with new Front tires I dont like the wear on them after 1 weekend racing - So I am going to re-check the alignment - I think It changed a bunch when I lowered the car. PICS: RF Fenderwell Window ![]() LF Fenderwell Window ![]() RF DOOR LIGHTENED ![]() RF Door Plate is Now AL ![]() More AL Plate ![]() Lightened Door Hinge: ![]() ![]() RF Cowl Lightened ![]() Bye Bye Fender Brace ![]() ![]() 9# of Stuff that does not go fast: ![]() Greg |
| Author: | Rob Simmons [ Thu Jun 23, 2011 10:28 am ] |
Thanks again for these updates with great pics Greg! Lots of good cutting ideas for the GodsRods Duster. Do you have a plasma cutter, or do you use something else? Classic Trucks magazine had an article on putting in a big rear window a couple months back. They recommended the cheapie $9.99 Harbor Freight metal saw. |
| Author: | Greg Ondayko [ Thu Jun 23, 2011 4:25 pm ] |
| Post subject: | 6-23-11 Cold Air Intake Thrash Complete |
So after Seeing some undesirable wear on my New ds-2's Front runners. I decided to invest in a set of toe plates and A Bubble Gauge for setting caster / camber. I figured the wear was caused mostly by toe; as I had the car up 2 years ago When It was aligned after Rebuilding the front suspension and converting it to discs. Now that it's much lower the toe was waay out. So I fixed that and I also installed a Cold air intake made of drain pipe parts. I'll Post Pics soon. Quote: Do you have a plasma cutter, or do you use something else? Rob, I wish I could afford a plasma cutter now, but nope I just use holesaws and cutoff wheels! Greg |
| Author: | Rob Simmons [ Mon Jun 27, 2011 8:33 am ] |
| Post subject: | Re: 6-23-11 Cold Air Intake Thrash Complete |
You inspire me! Greg Many of your cuts look like they were done with a plasma cutter. I don't think mine will be that nice. |
| Author: | Greg Ondayko [ Mon Jun 27, 2011 12:37 pm ] |
You inspire me!
Good Rob, I am glad That I inspire you!Many of your cuts look like they were done with a plasma cutter. I don't think mine will be that nice. Get that duster dooone so it'll be at Elk Creek. I might Be there too. Do you have a Plazma Cutter? I use a sanding disk and some files on the cuts and holes when I am done so I dont bloody Myself when I go to Work on the car Greg |
| Author: | Rob Simmons [ Mon Jun 27, 2011 12:50 pm ] |
Nope. No cool tools here either. I haven't even un-boxed my MIG welder yet! Thanks for the tip on finishing up the cuts. I thought they looked too nice to have JUST been done with a cut off wheel. |
| Author: | Greg Ondayko [ Thu Jun 30, 2011 9:45 pm ] |
| Post subject: | 6-30-11 Cold Air Intake and New Personal Record |
Well Here are the Cold air Intake Pics (below) Went to Test n Tune tonite To try out the cold air intake and 9.5#'s of weight reduction since last week. I got to make 4 runs - Run #1 is always a "throway" becaust the tranny and rear oil are not hot.. Run #2 I didnt set the Shifter correctly so did not do well there.. But then the 12.85 and 12.94 Runs at the end of the nite. ![]() This Cobbled up bits of Plastic Pipe seems to really Help the 60' Times Pretty Consistent on all 4 runs down in the 1.86-1.84 Second Range. Bye- Bye 1.90 60' Times Cold Air Pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() VIDEO OF 12.85 Run HERE 12.94(last Run of nite) ![]() Greg |
| Author: | Dart270 [ Fri Jul 01, 2011 6:27 am ] |
Congrats on the 60' times and best 1/4 time. Time to try w/pipe disconnected and connected to see if that's what made the differernce. 104 MPH is cookin'. Still think you have 12.50s lurking in that thing. Lou |
| Page 26 of 90 | All times are UTC-07:00 |
