It is currently Mon Nov 16, 2026 4:52 am
Post new topic  Reply to topic  [ 521 posts ]  Go to page Previous 1 … 31 32 33 34 35
PostPosted: Sat Feb 07, 2026 1:48 pm
What kind of modules are you running? GM? Chinese? Do you have a good ground on the system. And what voltage are you seeing at the module itself.
PostPosted: Mon Feb 09, 2026 1:03 pm
Car Model: 78’ dodge D100 slant six
All good questions that I hadn’t thought about. I’ve run grounds all over the charging and ignition system so I don’t think that should be an issue. Mostly run the standard lx301 I guess Chinese modules. Not sure on the voltage so I’ll check that and get back to yall.
PostPosted: Mon Feb 09, 2026 4:35 pm
I usually run a ground from the mounting screw of the module to the battery ground. Yes just verify your voltage at the module is not dropping off.
PostPosted: Mon Feb 09, 2026 7:59 pm
Make sure the module is well heat-sunk, and make sure your line voltage with the engine running isn't spiky or too high.
PostPosted: Tue Feb 10, 2026 6:42 am
Yeah! What he said too! :D :D
PostPosted: Tue Feb 10, 2026 11:42 am
I know it’s not to high as it only runs about 13 to 13.5 volts after the relay upgrade. I usually use heatsink paste instead of the line they supply unless that might be my problem?
PostPosted: Tue Feb 10, 2026 1:00 pm
That should be fine.
PostPosted: Tue Feb 10, 2026 4:23 pm
Car Model: 1966 Dodge Dart
13 to 13.5 is a decent battery voltage number when warmed up.
Matt Cramer
PostPosted: Tue Jul 07, 2026 2:59 pm
Long time no posts from me .
Looking at doing this conversion on another car .
Would this HEI Module work .
https://www.ebay.com.au/p/244608173?srs ... a3NxPf3qk5
I can't see it mentioned in Dan's retrofit discussion .
Cheers ,
Bucket
DRIVE IT,DON'T HIDE IT
PostPosted: Tue Jul 07, 2026 4:49 pm
Yes.
PostPosted: Tue Jul 07, 2026 10:04 pm
Yes.
Thanks Dan .
