| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 39 of 87 |
| Author: | Greg Ondayko [ Mon Jan 30, 2012 1:35 pm ] |
Quote: So probably great for this type of weight removal etc, but not quite precise enough for engine blueprinting type stuff (?).
Thanks! What are you talking about? .5g is .001 Pounds. I think that's plenty precise for engine stuff.. I weighed my pistons / rods / pins etc. on it. Greg |
| Author: | Rob Simmons [ Mon Jan 30, 2012 2:30 pm ] |
Well, ... I ain't a smart feller or a feller smart, and I ain't never dun it. That's why I put that little squiggly line with a dot under it at the end there... I wanna git more smarter on this stuff and wuz lookin' to you fer some answers. I s'pose I got one. Thanks! |
| Author: | Greg Ondayko [ Tue Jan 31, 2012 4:01 am ] |
Sorry Rob, I suppose I thought that everyone remembers how light 1g is from science class. You are right you did ask. I apoligize. Greg |
| Author: | Rob Simmons [ Tue Jan 31, 2012 4:45 am ] |
I wuz just funnin' with ya a little. I looked again at your previous post and realized that I missed the little dot thingy in front of the 5... Thanks for the answer. I'm gonna head up to Harbor Freight and git me one of them! |
| Author: | slantzilla [ Tue Jan 31, 2012 2:49 pm ] |
Quote: Sorry Rob, I suppose I thought that everyone remembers how light 1g is from science class.
I remember that 28.3 grams is an ounce, and not from science class. You are right you did ask. I apoligize. Greg |
| Author: | emsvitil [ Tue Jan 31, 2012 4:34 pm ] |
Quote: Quote: Sorry Rob, I suppose I thought that everyone remembers how light 1g is from science class.
I remember that 28.3 grams is an ounce, and not from science class. You are right you did ask. I apoligize. Greg 28.349523125 grams in an ounce...... |
| Author: | sandy in BC [ Tue Jan 31, 2012 7:43 pm ] |
454g to the pound.........thats a lot of hash........or titanium. |
| Author: | slantzilla [ Tue Jan 31, 2012 7:53 pm ] |
Quote: 28.349523125 grams in an ounce...... You have a much better scale than I had. |
| Author: | sandy in BC [ Tue Jan 31, 2012 7:57 pm ] |
Postal scale with alligator clip? |
| Author: | emsvitil [ Tue Jan 31, 2012 8:04 pm ] |
Quote: Quote: 28.349523125 grams in an ounce...... You have a much better scale than I had. |
| Author: | Greg Ondayko [ Wed Feb 01, 2012 6:59 pm ] |
| Post subject: | 2-1-12 Converter Swappin' |
I dropped the trans for the converter swap. I am also putting in some New Synthetic fluid, A new filter - Re adjusted the bands, Swapped converters and flexplates. While the Trans is out I will be scraping the floorboards of any more Rust proofing.. Probably got 5 # more in the trans tunnel alone. Pics: Black converter out - Green Converter in. ![]() Flexplate comparision - Both of these Started out as LA-904 TCI Flexplates.. I redrilled the One Crank hole on both and one of them is modded to accept the stock type 5/16" converter Bolts... THe other is for the larger racing style 7/16" converter Bolts. ![]() Green converter in fo a test fit.. I have to make sure the welds on the lugs fit correctly before final welding. ![]() Greg |
| Author: | Dart270 [ Thu Feb 02, 2012 6:14 am ] |
I guess we were working on trannys in parallel last night, Greg. Got the new Midwest converter and the trans back in and running in the '68. Too easy to spin tires in the garage... Rainy so didn't get to test real stall yet. Lou |
| Author: | Greg Ondayko [ Sun Feb 05, 2012 7:11 pm ] |
| Post subject: | Trans In / Pan Evac Complete 2-5-12 |
After test fitting the trans to make sure the lugs that I tacked on the converter were right after it was in the car I had one lug that was a bit off.. the others were lining up well. So I made the adjustment and did a full weld on all 4 lugs. ![]() While I had the trans out I was able to remove 2.6# of undercoating and other Junk from the car! ![]() Box Tare is 0.68# ![]() Ruster Should now weigh 2198.1# I filled it up with some Amsoil Synthetic Trans ATF. (Ryan Peterson Will Be Proud) ![]() Need TP for My BungHole ![]() Pan Evac and 02 sensor Bungs installed in the collector extension. (no 02 Sensor in there yet.. but soon!) ![]() ![]() Pan Evac Complete! ![]() Greg |
| Author: | terrylittlejohn [ Mon Feb 06, 2012 5:26 am ] |
looks nice, but shouldn`t the o2 be lower in the exhaust stream? the bung looks a little high holding the sensor up in the bung. |
| Author: | Greg Ondayko [ Mon Feb 06, 2012 7:25 am ] |
Quote: looks nice, but shouldn`t the o2 be lower in the exhaust stream? the bung looks a little high holding the sensor up in the bung.
Good Observation..With this sensor it says to use that high bung with leaded race gas.. It is mostly Shielded from the lead deposits which will damage the sensor. Greg |
| Page 39 of 87 | All times are UTC-08:00 |
