| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 40 of 87 |
| Author: | terrylittlejohn [ Mon Feb 06, 2012 2:17 pm ] |
will you have it right , nice to know |
| Author: | Greg Ondayko [ Sat Feb 11, 2012 11:55 am ] |
| Post subject: | 12-11-12 Brake Drum Lightening |
Here are some shots of the Rear Brake drums before their Diet. ![]() ![]() Left - Weighed 11.5# ![]() Right Drum - Weighed about the same - ~11.3# Nither of the drums would weigh in on my 5000g Small scale - FYI 5000g = 11.02# ![]() I took the Drums to the local machine shop to get the "ridges" machined off. Here's what they looked like when I got them Back: ![]() ![]() Here's the weight back from the machine shop: Right: 10.262# ![]() Left: 9.770# ![]() THen I decided I wanted to get more weight off of these.. I think THe machine shop was afraid to cut into them more than what they did. I have no lathe yet or a buddy near by with one so I bolted up my axle puller on one bolt hole and welded in on the other side and chucked it up in my drill press.. ![]() ![]() ![]() I used the Angle Grinder alot on the drill press.... and Here's what I got: ![]() ![]() ![]() Left: ![]() Right: ![]() Weigh In: After Drill Press and Grinder: Left: 9.142# ![]() Right: 9.694# ![]() That is a total weight loss of 3.964# - Roatating weight too! Greg |
| Author: | Greg Ondayko [ Sat Feb 11, 2012 2:53 pm ] |
| Post subject: | Weigh In |
After the Brake Drum Grinding.. Ruster was 2198.1# - 3.96# Brake Drum Grinding _________ 2194.1# Ruster's current Calcualted weight I have a few more ounces to find... They are there.. I just need to get them cut off the car! Greg |
| Author: | Dart270 [ Sun Feb 12, 2012 2:11 am ] |
Should I bring scales to MD? How much fuel at that wt? Lou |
| Author: | emsvitil [ Sun Feb 12, 2012 2:13 am ] |
Why the big difference in weight L to R ? |
| Author: | Greg Ondayko [ Sun Feb 12, 2012 5:14 am ] |
Quote: Why the big difference in weight L to R ?
These were 2 unmatched brake drums that I had just layin around for ruster when I sapped to the Big Bolt pattern.. They were 2 of the lightest stock drums that I found off of the many 8 1/4 & 7 1/4 FJM rears that I have parted or sold over the years.. They had no Fins or big Bell flares to start with!The heavier one goes on the Right @ Lou.. That weight should be with a 1/2 cell of fuel say 2.5 Gal... and sure if you can bring scales I would greatly appreciate it. Greg |
| Author: | Dart270 [ Sun Feb 12, 2012 5:51 am ] |
Cool. Remind me 1-2 days before the race. Lou |
| Author: | Greg Ondayko [ Sun Feb 12, 2012 8:28 am ] |
| Post subject: | Losing again.2-12-12 |
Today I Installed the Lightened Rear Brake Drums: ![]() Polished the aluminum Wheels - They were a bit scuzzy from not having an enclosed trailer and also pulling in alot of rain. Lost another 1.6#.. Removed the bolts for frame connectors.. I used the bolts to locate them waay back whenI welded them in.. But I got lazy and never took the bolts out.. Also scraped off more undercoat and other junk. ![]() Already tare'd the box before taking this shot. ![]() 2194.1# -1.6# Ruster's Current Calculated weight: 2192.5# Greg |
| Author: | Rob Simmons [ Mon Feb 13, 2012 2:55 pm ] |
You're SICK Man! SICK! I love it! |
| Author: | Dart270 [ Mon Feb 13, 2012 3:11 pm ] |
Can't you cut those 3" wheel studs down some. Sheesh, man! Is there a spool in that thing already? That's a chunk of wt. Lou |
| Author: | slantzilla [ Mon Feb 13, 2012 3:51 pm ] |
Quote: Can't you cut those 3" wheel studs down some.
Believe it or not, on the NPS Camaro I helped on at the race car shop we did that...............................................to titanium studs. |
| Author: | Greg Ondayko [ Mon Feb 13, 2012 4:52 pm ] |
Thanks guys.. I like being sick..cough cough... My meds dont seem to be working.. Oh well. Had Valentines dinner tonite and now getting back to more cutting on ruster.. I think I am keeping the wheel studs for now... Some sort of IHRA / NHRA rule about them? The fronts are stocker studs for now. That might change when I get some wilwood dynalites up front in the next year or 2! Will post more updates soon. Greg |
| Author: | Greg Ondayko [ Mon Feb 13, 2012 7:36 pm ] |
| Post subject: | 2-13-12 Cowl Hack Sheds Another pound off the Front |
I have been eyeing up this spotweld seam for a while! Here are the Shots of the Seam before the Cutter hit it.. your Typical Stock A Body Cowl Area.. Some of the Spots have 4 layers of metal swandiched in there! ![]() ![]() ![]() I will do the same thing here as I did on the 4 door frames... Cut all the spot weld / Pinch weld areas out and then weld them back up flush. After cutting / before Welding: ![]() ![]() ![]() ![]() ![]() And the weigh In: ![]() ![]() Got 1# off the Front today...success.. The Box Tare's @.680 so it's just 1#. Ruster Calculated weight: 2192.5# - 1.0#= 2191.5# Greg |
| Author: | Greg Ondayko [ Fri Feb 17, 2012 7:27 pm ] |
| Post subject: | 12-17-12 Cowl Welded up |
Well I got the last major bit of winter project(s) complete on ruster today... Welding up the cowl where I had sliced off the spotweld / pinch weld area. Pics: Cowl Area Being Welded: ![]() ![]() ![]() Cowl Painted and Finished: ![]() ![]() A few Glamour Shots: I finally got to start ruster up and pull it out of the garage.. I think the Green converter will be too tight but I can use it while I send the other one back to midwest to get the stall speed raised up to 5000RPM. ![]() ![]() ![]() ![]() ![]() Greg |
| Author: | terrylittlejohn [ Sat Feb 18, 2012 1:34 am ] |
car is sure looking great also the grass! haven`t seen grass for 3 months now only 2 more too go!!! |
| Page 40 of 87 | All times are UTC-08:00 |
