It is currently Wed Dec 24, 2025 11:11 am
Post new topic  Reply to topic  [ 1294 posts ]  Go to page Previous 141 42 43 44 4587 Next
PostPosted: Sat Apr 07, 2012 7:17 am
Greg:
I've spent ALL DAY looking at this thread and absorbing as much of it as possible... not sure if I want to get as many holes as you have with Ruster, but you've given me the inspiration to really take a second look at how I've got my Dart setup...
She's a pig, albeit a very light pig (even from the factory) but now Im seeing TONS of stuff and thinking... "Why do I need that?"
Uh oh... you are starting to get me roped in now... :shock:
Excellent job on Ruster! Just curious, how many cans of black paint have you gone through? LOL :twisted:
~THOR~
Thanks Thor,
This thread will always be here for your reference..
There are still a lot of things to be lightened..
Some of them cost alot of $ so They will wait a bit.
I estimate about ~15 cans of Black so far..
 Post subject: Paint
PostPosted: Sat Apr 07, 2012 9:13 am
Greg, 15 cans at 1 pound each is 15 pounds! What are you thinkin man!! Rust is lighter than paint!!! :lol: :lol:
 Post subject: Re: Paint
PostPosted: Sat Apr 07, 2012 11:33 am
That's before the solvents flash off.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Apr 07, 2012 11:38 am
Yeah, I thought about that too.I sprayed the underside and running gear of my 64 and looks like most of it was on the shop floor.
 Post subject: Update 4-7-12
PostPosted: Sat Apr 07, 2012 3:08 pm
I am waitning on a Few parts from A&A to Finish my transmission Swap / Refresh.
While I was Disassembling the front pump to replace the Converter bushing I found that the engine running the pump gear with no belhousing to support it wiped the Gear and Back Half of the Pump section too.. So I cleaned up a donor gear and rear half of a pump section.
The Final weigh In of all the New Yokes and drive shafts are complete:
Even though I am upgrading the Strength and durability of these parts I am not Happy that the 1350 u joints and yokes and AL drive shaft ADD 1.44# to the Driveline :-(
Hopefully I can offset this travesty by Eliminating the Governor and Swapping to a Billet Aluminum Park Gear.. We shall see.
While I am waiting on trans Parts I put a flywheel and starter on the engine - I fired it up just to be sure that I didnt break any thing there.. I would hate to assemble the trans and everything into the car to find an engine problem...
It was all in good shape - YAY.
Pics:
New Driveshaft:
It weighs 10.93# Almost 1.5# More than the broken steel one.
Old Steel / Stock Driveshaft weights 9.57#
New 1350 Trans Yoke for the 904:
It weights 3.32# ------- .32# More than the stock one.
Old Trans Yoke - Weighs 3.0#
New 1350 Yoke for the rear End:
It Weighs 2.31# (.20# Lighter than the stock one)
Rear Yoke installed:
Yoke Holding tool made from old Bed frames: - 1350 & Small Mopar.
Hopefully the Removal of the Governor and the AL park gear will Get my 1.44# Back.
PostPosted: Sat Apr 07, 2012 5:03 pm
Just asking Greg, but why did you go to the 1350 joints?
Mike even had 7260 joints in the blue Buzzin' car. :?
PostPosted: Sat Apr 07, 2012 5:14 pm
Just take a healthy crap before racing and you won't even notice the 1.44 lbs. :P
PostPosted: Sat Apr 07, 2012 7:06 pm
I wanted the over engineered stuff that Will be hard to break. I haven't had Much Luck with the Smaller Stock stuff on the dart or on this car.
I also like the fact that the caps are retained on the Outside rather than the inside. Personal Preference.
PostPosted: Sat Apr 07, 2012 7:08 pm
Yeah But my 1.44# of Crap isn't rotating in the driveline. :shock:
If it is I have some kind of problem to work out..
PostPosted: Sat Apr 07, 2012 8:34 pm
HAR-HAR,,,,!!!! :lol:
PostPosted: Sun Apr 08, 2012 10:14 am
I always like overkill
Ive seen some oldschool short cuts put peeps in the ground
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Apr 09, 2012 6:35 am
I'm amazed that your stock DS was that light. It must have been pretty rusted/flaked. I usually get 16-19lbs for an A-body DS with slip yoke.
PostPosted: Mon Apr 09, 2012 10:49 am
@USA Jon, Yep I dont want any racing stuff to put me in the ground.. I have had my share of smallish mishaps that no one was ever hurt in 'cept my pocketbook.
@ Lou - I don't know what to tell ya - - I never weighed much of any car part before the Ruster project...
This car was on Salty PA roads from'68-02ish
then it sat in the back of my dad's lot from '02- 2009.
Then The Ruster Project began.
This was the stock '68 Valiant shaft that came with the car -& I had it shortened as well when I put the 8 3/4" In.. I remember the Driveshaft shop had removed alot of the scale when I got it back - possibly alot of the mass was removed by the rust and welding etc.
O2 Sensor is in:
(it's reading dead Lean 'case I dont have an starter in the car to run the engine)
PostPosted: Mon Apr 09, 2012 11:12 am
It's possible your "lightened" shaft was weak and crumpled up when it spun up under overwhelming torque... :shock:
PostPosted: Fri Apr 13, 2012 7:51 pm
Probably one of the best Friday the 13th's I have seen in a while..
I thrashed on Ruster for the Last Few days to get the Trans assembled and In the car.. When I ordered some parts fro the 904 From A&A trans I opted for the Billet park Gear and the Governor Delete Sleeve.. these pieces are for a full boogie manual Shift trans - If you can still get all 3 gears in "D" Dont install these - You will blow up or ruin something.
The Weight I Added with the Driveshaft I more than mad up for Bu suning the Super Light Trick A&A trans parts.
Hitting the TNT here in pittsburgh Tomorrow.. I dont want to drive to MD and have something blow up or fall out in front of any of the covalts.. :oops:
Pics:
Old Steel park Gear & Governor Removed - Weighs a Hefty 2.81#
New Flyweight Billet Gear & Sleeve Weighs 0.690#
Parts Installed:
So after Putting the Aluminum parts in the trans I am now .68# Lighter than Before..
2191.5-0.68=
2190.82# - Inching ever closer to the 2100# mark!
I will make some passes tomorrow and post updates.
Cheers!
