| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 54 of 90 |
| Author: | Rob Simmons [ Thu May 23, 2013 6:47 pm ] |
Great to hear Greg!! Hamilton/N. Wilkesboro next month..? |
| Author: | Greg Ondayko [ Thu May 23, 2013 7:02 pm ] |
Quote: 100% on the sickness. Do you still have a dash frame? Learned a lot from the racer crowd. A couple of them didn't wanna tell me the vehicle weight though
Glad you did not find any problems! I used to run the 6x1 header and it worked pretty good. I have No dash Frame - That's about 10-20#'s - I removed that when I took the windshield out and went Lexan. |
| Author: | Greg Ondayko [ Thu May 23, 2013 7:03 pm ] |
Quote: Great to hear Greg!!
That's The Plan. - We'll see if it holds together Hamilton/N. Wilkesboro next month..? Greg |
| Author: | Dart270 [ Fri May 24, 2013 7:06 am ] |
Good news, Greg! Gee, I wish I had listened to your car now. I have heard that noise several times and it distinct from rod knocking. Interested to see the header results.... Lou |
| Author: | Greg Ondayko [ Fri May 24, 2013 7:17 am ] |
Thanks lou, I wanted to save the parts so once I suspected rod knocking I even winched it up onto the trailer - Better to Be safe and Save a few bucks and have it turn out this way.. I have already learned my lesson with the Dart - I fried a rod and crank after running it with a "noise" in the motor. Greg |
| Author: | slantzilla [ Fri May 24, 2013 7:48 am ] |
Greg, not sure why but I couldn't keep converter bolts tight on mine either. Tried 2 different transmissions, 3 different converters, and 3 flexplates. Red Loctite wouldn't even hold. Hope you have better luck. |
| Author: | Greg Ondayko [ Fri May 24, 2013 8:16 am ] |
I might Just take the bolts to my competent machinist and Have them drilled for safety wire... Then I'll tie them together with the wire and locktite Greg |
| Author: | Exner Geek [ Fri May 24, 2013 6:27 pm ] |
Stage 8 fasteners makes torque converter bolts that utilize aluminum tabs and snap rings to positively lock them. |
| Author: | Greg Ondayko [ Fri May 24, 2013 6:40 pm ] |
Quote: Stage 8 fasteners makes torque converter bolts that utilize aluminum tabs and snap rings to positively lock them.
Another Good option. Good to know and thanks for sharing, Seymour. Greg |
| Author: | Ron Hamby [ Thu May 30, 2013 4:33 pm ] |
Greg, My computer has been down a few days, so I didnt know about the good news till now. I have had converter bolts come loose a couple of times as well. Now Im always worried about them coming loose again even with locktight. Im glad Ruster is healthy. Ron |
| Author: | Greg Ondayko [ Thu May 30, 2013 8:40 pm ] |
Yep Should be all good. I should get 2 local test sessions here at home before going to Wilkesboro... I wanted to try out the Hooker Super comps and I also have a set of 4.88's Built on the stand that Maybe Will lower my ET? Possibly these would be for my 1/8 Mile setup? Wee shall See. Greg |
| Author: | NCDemon1971 [ Sun Jun 30, 2013 6:13 pm ] |
This is an addictive thread. I must have missed it but, how many point cage do you have? Chrome Moly? Where do you get one? |
| Author: | Greg Ondayko [ Tue Jul 02, 2013 3:50 pm ] |
| Post subject: | 7-2-13 |
Quote: This is an addictive thread. I must have missed it but, how many point cage do you have? Chrome Moly? Where do you get one?
Thanks, The Kit I got Was a competition Engineering Kit. It's Chromemoly - Needs to Be TIG/GTAW welded in and you can learn alot of Fabricitating skills if you wish to take the task on yourself. I suggest to Get a Tubing Notcher (woodward Fab/ Summit Has Cheaper ones) And at least a Hot / Chop Saw. Here is a Link to where it is on this thread.. http://slantsix.org/forum/viewtopic.php ... &start=720 The Kit has 2 Part Numbers: Links Below The Hoop (which is Pretty Specific to your car / application) and the Strut Kit which is somewhat more universal and will take time and a lot of cutting / Sanding Grinding to fit up correctly. http://www.summitracing.com/parts/cee-3158 http://www.summitracing.com/parts/cee-3100 IN OTHER RUSTER NEWS... I got the 4.88 Gear Set in - The 8.75 Chunks weigh 60# each - the 4.56's weighed the same as the 4.88's The Hooker headers were also .2 Slower in the quarter Mile as compared to the Mopar Performance 6 into ones.. so I took those back off as well. I will report back on the 4.88's to see if anything is quicker with those. Greg |
| Author: | NCDemon1971 [ Tue Jul 02, 2013 4:41 pm ] |
Thanks for the info Greg. I am surprised by the performance of the headers as well. I figured the Hookers would out do the Mopar ones. But it may depend on the combo?? |
| Author: | Greg Ondayko [ Tue Jul 02, 2013 7:27 pm ] |
Quote: Thanks for the info Greg. I am surprised by the performance of the headers as well. I figured the Hookers would out do the Mopar ones. But it may depend on the combo??
It's Possible that it's the Combo. The Mopar Performance ones are a bit shorter in where the collector area comes together... in other words the Primary tubes are shorter on them. The hooker and Cliffords have about 2" Longer Primary Rubes. I might be interested in making an even shorter set and seeing if that helps. Greg |
| Page 54 of 90 | All times are UTC-07:00 |
