| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 56 of 90 |
| Author: | USAJon [ Sun Jul 28, 2013 2:47 pm ] |
I understand but you should be able to spin tires off the line some...even with a line lock |
| Author: | Rick Covalt [ Tue Jul 30, 2013 1:28 pm ] |
Greg, do you have a part number on the torque convertor bolt kit you got from Stage 8. I went to order a set but I don't see them listed specifically for the torque convertor on their web site? Mine are the smaller 5/16" bolts too. Thanks. Rick |
| Author: | Greg Ondayko [ Wed Jul 31, 2013 2:31 pm ] |
Quote: Greg, do you have a part number on the torque convertor bolt kit you got from Stage 8. I went to order a set but I don't see them listed specifically for the torque convertor on their web site? Mine are the smaller 5/16" bolts too. Thanks.
Rick,Rick Here are the ones I used.. They are listed for a GM. http://www.summitracing.com/parts/stg-8965-a They are the Big 7/16-20 Thread Size for my converter. Maybe you can find a thread size that is appropriate from this list and just order an alternate part? http://www.stage8.com/moparother.html Greg |
| Author: | Greg Ondayko [ Sun Aug 04, 2013 8:22 pm ] |
| Post subject: | 8-4-13 Rear Disc Install and Back to 4.56's |
Hello, I Bought a Wilwood Dynalite rear drag Kit for Ruster and Got it installed this weekend. I also reset the Pinion Depth on the 4.56's and reinstalled them. Here are some comparisons between the Weight of the Factory Drums & associated Parts, including Parking Brake and bracketery, to the Wilwood kit which has no Provisions for a parking Brake. Here are Some Of the Drum Parts that had been removed: ![]() ![]() That Box of parts was 9.044# ![]() Then The Backing Plates; They Weighed 6.360# for one and the other was 6.392#. ![]() Then The 4 Brake Shoes.. ![]() They Weighed 6.300# ![]() All of the Non Rotating parts removed total was 28.096# I had weighed the Drums at an earlier date and Marked the Weights of each one on the inside of the drum; They weighed 9.770# and 10.264#, for a total of 20.034# of rotating Mass on the Rear Drum Setup. The Total Rear Drum and Parking Brake setup was 48.13#. Now for what replaced it: The Wilwood kit has Aluminum rotor hats and A Drilled Rotor that weighs in at 6.280# per Side. ![]() ![]() That's a total of 12.560# of Rotating Mass for the Rotor Kit versus 20.034# for the drums. That Means 7.474# Less Rotating Mass with the rotors! YAY. Here is the Rest of the Kit; all of the stationary pieces: ![]() The Hose, caliper, 2 adapters, Pads and Caliper Mount/ Axle retainer weighed in at 5.078# Per Side for a total of 10.156# as opposed to 28.096# of Non Rotating Mass for the Drum Setup. ![]() Drum Setup Total Weight: 48.13# Disc Setup Total Weight: 22.716# Ruster Lost: 25.414# YAY! Here is what the Kit looks Like installed: ![]() ![]() ![]() So with Loosing 25.414# Ruster Will be lighter - But what is the total weight now? We have to look all the way back to January 28, 2013 to see: http://slantsix.org/forum/viewtopic.php ... &start=750 At Last Check Ruster was 2184.1# Take out 25.414# That Leaves us at 2158.7# I am pretty Close to the bottom of B gas slat class with driver Now.. at 2377.5# I will try to Hit test n tune this week at pittsburgh to see if i can get back into the 11's with these changes, at a higher altitude track. Greg |
| Author: | Dart270 [ Mon Aug 05, 2013 11:34 am ] |
Greg, Nice work. Any chance you will make Bristol? I could lend you my corner scales while I'm away, if you're interested??? Lou |
| Author: | Greg Ondayko [ Mon Aug 05, 2013 12:25 pm ] |
Quote: Greg,
Probably Not Bristol This Year.Nice work. Any chance you will make Bristol? I could lend you my corner scales while I'm away, if you're interested??? Lou MAson Dixon And Clay City are more Likley Greg |
| Author: | Dart270 [ Mon Aug 05, 2013 1:51 pm ] |
Cool. I'll be gone after Bristol. Could hand scales to Covalts at Bristol if you want 'em. Lou |
| Author: | Greg Ondayko [ Mon Aug 05, 2013 4:58 pm ] |
Quote: Cool. I'll be gone after Bristol. Could hand scales to Covalts at Bristol if you want 'em.
Sounds like a great deal... when would you need them back by? spring mason Dixon 2014?Lou Greg |
| Author: | Dart270 [ Mon Aug 05, 2013 7:31 pm ] |
Yes, spring M-D race would be fine, and you could even keep them into the summer if you like. I just weighed all my junk, so I'm good for a while. My 64 Dart is down to 2940 lbs with me (176 lbs clothed) and 18 gals of gas... We weighed my friend's 2009 Civic LX also, and it is the same - 2745 w/full 13 gal tank plus me equals 2930! With only 13 gals on board, my car is lighter... Lou |
| Author: | slantzilla [ Mon Aug 05, 2013 11:21 pm ] |
Quote: I understand
Why would you want to?but you should be able to spin tires off the line some...even with a line lock Automatic cars dead hook. Stick cars need wheel speed. |
| Author: | Greg Ondayko [ Fri Aug 09, 2013 7:36 pm ] |
| Post subject: | Tnt 8/8/13 |
Test n Tune 8/8/13 I went back to the 4.56 gear and had the rear discs othe car now. the 4.56s used to whine and howl then they got warm.. so I had mismeqsured the pinion depth.. not that I have the correct pinion depth measurement tool for setting up 8.75 rear ends I decided to measure and reset th depth correctly.. I got in within 0.002". reset the gear lash.. noise was gone, but I think the gears were possibly settling in again.. I made 5 runs and the barometer was reading 29.70 and rising up to 29.9x by the end of the night. air was 70 to 80 degrees and humid in the 80% so air was not great. car picked up as air got Better and I was back into the 12.20s by the end of the night which compared to my notes from similar air pressure/ tempature/ humidity conditions. in better air and possibly lower elevation should be able pick up .2-.25 seconds.. which would put me back into the 11s.. I will have to wait until fall and spring. next expierement will be carb spacer here were the times: run1 12.39@106 run2 12.38@106 run3 12.32@107 run4 12.25@107 run5 12.27@107 Greg |
| Author: | Romeo Furio [ Sun Aug 11, 2013 5:55 pm ] |
A carb spacer should pick up a few 100ths. Worked for me on everything I ever ran.Maybe as much as a 10th or so. I gave Brian a few last week. I think they were 2''.Maybe he will loan ya one. |
| Author: | Greg Ondayko [ Tue Aug 13, 2013 12:15 pm ] |
Quote: A carb spacer should pick up a few 100ths. Worked for me on everything I ever ran.Maybe as much as a 10th or so. I gave Brian a few last week. I think they were 2''.Maybe he will loan ya one.
Good to know Romeo, I have one but now I know where to get a few more... have a good winter.. Greg |
| Author: | USAJon [ Tue Aug 13, 2013 2:54 pm ] |
Quote: Quote: I understand
Why would you want to?but you should be able to spin tires off the line some...even with a line lock Automatic cars dead hook. Stick cars need wheel speed. http://www.youtube.com/watch?v=7ORu0arjToc |
| Page 56 of 90 | All times are UTC-07:00 |
