| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 58 of 90 |
| Author: | NCDemon1971 [ Fri Oct 11, 2013 12:11 pm ] |
Greg, How many jet changes did it take to get that 750 right? I thought about using one... |
| Author: | Greg Ondayko [ Fri Oct 11, 2013 2:08 pm ] |
Quote: Greg,
How many jet changes did it take to get that 750 right? I thought about using one... The 750 Carter was pretty Close - Either stock Jetting or one change.. The 750 Holley I coult not get to run right. I think it's too Big for the engine or I have not fiddled with it enough yet. Greg |
| Author: | Rick Covalt [ Sun Oct 13, 2013 11:51 am ] |
Greg, Did your oil pump have the extra tube to spray oil right onto the gears? At least going to the external pump will allow you to reuse the cam if you want. I am glad that it didn't tear things up really bad. Rick |
| Author: | bmimken [ Sun Oct 13, 2013 1:34 pm ] |
Greg, glad it was not any worse! You have had a challenging year, but you have kept a positive outlook! I look forward to seeing Ruster at the track next year going even faster!! Brian |
| Author: | terrylittlejohn [ Sun Oct 13, 2013 4:31 pm ] |
ever since I have used doug`s positive oiling tips on the cam/oil drive gears I have no problems up to 6800rpm. also with a polish of the gear teeth to take the sharp edges of before running it. the drilled pump from the pressure side is the best compared to the tube feed line. |
| Author: | Greg Ondayko [ Sun Oct 13, 2013 4:53 pm ] |
Quote: Greg,
No I did not do that mod.Did your oil pump have the extra tube to spray oil right onto the gears? At least going to the external pump will allow you to reuse the cam if you want. I am glad that it didn't tear things up really bad. Rick I was too anixous when I did the build the first time. I probably should have done the oiling gear mod. It was time to pull the engine apart anyway... this was a good excuse to do so. Greg |
| Author: | Romeo Furio [ Mon Oct 14, 2013 6:21 am ] |
That's it,,Positive out look ! |
| Author: | Dart270 [ Mon Nov 04, 2013 10:32 pm ] |
Lovin' it, Greg! You will have the lightest 2nd gen A-body on the planet soon... I only reuse stock used pumps and regrind cams now, and no problems yet. Tilley told me the same thing recently, that he had switched to that mode. Lou |
| Author: | SIX GUN [ Tue Nov 05, 2013 7:13 am ] |
Greg; I remember a MoPar guy that hole-saw his K-frame and, put a rack/pinion steering on it... Do they make a chromoly tubular K-frame??? |
| Author: | Romeo Furio [ Tue Nov 05, 2013 8:34 am ] |
Check out QA1 for 67 up tube K frames |
| Author: | Greg Ondayko [ Tue Nov 05, 2013 8:42 am ] |
Quote: Check out QA1 for 67 up tube K frames
Thanks Romeo! already Know about it. But thanks for throwin it up here. I have not seen a price or weight on them yet I can also Modify a stock one with some 4130 Tube too:-) Greg |
| Author: | Greg Ondayko [ Tue Nov 05, 2013 8:44 am ] |
Quote: Greg;
I remember a MoPar guy that hole-saw his K-frame and, put a rack/pinion steering on it... Do they make a chromoly tubular K-frame??? Yep I might Grind a Bunch out of it this winter. Not yet sure on the rack / Pinion Setup. Greg |
| Author: | slantzilla [ Tue Nov 05, 2013 9:43 am ] |
Greg, unless you really, really need a lot of room for oil pan/headers I would stay away from rack and pinion. It opens up a whole can of worms for front end geometry, and most of it is bad. Yes, you can cut a ton of weight out of a stock K-frame, and it will bolt in when you're done. |
| Page 58 of 90 | All times are UTC-07:00 |
