| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 63 of 92 |
| Author: | Greg Ondayko [ Tue Apr 08, 2014 7:29 pm ] |
| Post subject: | 4-8-14 Ruster Runs on Megasquirt 3 & 6 coils |
Quote: Awesome work Greg!!
thanks Brian, good to hear from ya! tonight was the first time ruster has run since october. this time with no distrubitor or factory oil pump. still need to tidy up all the wiring and mount the front end & radiator on. plenty of work to do; not sure if it will be done for mason Dixon 2014, but if not I have another slant car I can bring. pics wil be postted sometime. Greg |
| Author: | Rick Covalt [ Mon Apr 28, 2014 6:49 pm ] |
You da man Greg! Now with all that new bling on there you need to treat yourself to a new piece of dryer duct for the carb!! You have done a huge amount of work over the winter. I hope it runs well and you can bring it to Mason Dixon. Rick |
| Author: | Romeo Furio [ Mon Apr 28, 2014 7:52 pm ] |
Lovin' it ! |
| Author: | Will [ Wed Apr 30, 2014 3:31 am ] |
You are more than welcome. I am always happy to try to help. Will |
| Author: | SIX GUN [ Wed Apr 30, 2014 5:58 pm ] |
I think I have to watch out, you'll be in the 11.s easy !!! |
| Author: | Greg Ondayko [ Wed Apr 30, 2014 6:27 pm ] |
Quote: I think I have to watch out, you'll be in the 11.s easy !!!
that's what you think... I don't believ it until I have 10 time slips with all varying track and weather wind conditions that start with 11.xx. Greg |
| Author: | Greg Ondayko [ Fri May 02, 2014 8:27 am ] |
| Post subject: | 5-1-14 |
Well i went to to track and Have some bugs to work out. I don't even remember what the et's were... just bad/ slow I was struggling to stay in the 12's with High speed misfires etc... Not sure if its a trigger wheel / Hall sensor error , Maybe the coils need more dwell, or possibly The spark Plugs I used dont work well with this engine combo( the old plugs were removed as they were fuel soaked from Trying to start the car when I first installed MS3/ Trigger wheel) The Vacuum pump works too well. I have a regulator on Order to tame the vacuum pump, & suck less oil out of the engine. I learned that too much vacuum in the crankcase might not be good. I might have to rework some of the internal valve cover baffling as well. Also I have some of the original (pre Coil on Plug) spark plugs on order too. We'll see if I can get it sorted out. Greg |
| Author: | slantzilla [ Fri May 02, 2014 10:19 am ] |
I was just going to post to be careful with the vacuum pump. Get too much and it can draw oil away from the pickup and hurt the crank. I believe the number is no more than 14 inches. |
| Author: | Greg Ondayko [ Fri May 02, 2014 10:44 am ] |
Quote: I was just going to post to be careful with the vacuum pump. Get too much and it can draw oil away from the pickup and hurt the crank. I believe the number is no more than 14 inches.
Thanks for the insight.That's why I am going to get the regulator. One of the track techs was nice enough to spend some time and offer up some suggestions that correlate with yours Dennis. I am new to all this Vacuum Pump Stuff.. so live and Learn! (better than living and not learning) Greg |
| Author: | Dart270 [ Sat May 03, 2014 10:40 am ] |
LOTS of new changes to that car, so teething is unavoidable. Congrats on getting it fired and to the track! See you M-D, Dr. Ruster, with your Frankenstein or without... Lou |
| Author: | DadTruck [ Tue May 06, 2014 2:02 pm ] |
Greg very impressive,,nice work! |
| Author: | Sam Powell [ Mon May 26, 2014 6:57 am ] |
That looks great Greg. I want to ask you sometime about how the Mega Squirt is configured for your ignition, and what type of coils you are using. Sam |
| Author: | Romeo Furio [ Mon May 26, 2014 9:44 am ] |
Greg, I too was having a high speed miss when I put the new car together. I went after everything electrical and still had it. Not saying this is your case,, Mine was in the jetting. and not what you would think. Instead of a lean pop, it was too rich. After chasing my tail for a while,and as a old schooler(not having a air/fuel meter) I took a chance and started with metering rods leaning a little at a time. Just a thought.. |
| Page 63 of 92 | All times are UTC-07:00 |
