| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 66 of 92 |
| Author: | Greg Ondayko [ Tue Dec 01, 2015 1:33 pm ] |
Quote: looks like your also going from a 3clutch to a 5clutch drum. are you going with the up dated coil spring front piston like a 727?
Yes - It has the 904 version of the 727 Spring pack!Greg |
| Author: | wvenable [ Thu Dec 17, 2015 3:08 am ] |
Lookin' good Greg! |
| Author: | Greg Ondayko [ Thu Dec 17, 2015 9:17 am ] |
Quote: Lookin' good Greg!
Thanks WV.I love the Poser status in your avatar - who set that up? Greg |
| Author: | Will [ Thu Dec 17, 2015 12:16 pm ] |
Looks like holding power to me. |
| Author: | wvenable [ Thu Dec 17, 2015 12:38 pm ] |
| Author: | Greg Ondayko [ Thu Dec 17, 2015 1:28 pm ] |
Quote: Looks like holding power to me.
I somehow managed to run 11s on 6 clutches. I hope there is more power to the tires with 10 clutches. Maybe I was giving up some et through slippage?We will see! Greg |
| Author: | Greg Ondayko [ Sun Jan 31, 2016 6:18 pm ] |
| Post subject: | 1-31-16 |
HAPPY BELATED NEW YEAR! While most people have forgotten their new year resolutions or failed to keep them, I stared on my 2016 Resolution Back in December of 2014... Saving some Ca$h to get some Aluminum and Roller 904 Goodies from Rick at A&A Transmission. It was a Nice 64* here today on January 31.. which is welcome when you want to open the garage door, fire up the car, change the oil, check the Trans fluid, and run the freshly assembled Trans through all of the gears. For the Fresh Trans Build and Parts... I am happy to report That I just needed to do a shift cable adjustment to keep the Gear selector from flip- flopping between "N" and "D" but otherwise it seems to be in great shape! March 5th Is Opening Day at Mason Dixon - Probably a Full month before anything around here opens up, I cant wait! Time to Double check everything, Install New Seat belts and Hang the Front Facia and go Slant Six Racing 2016! Greg |
| Author: | Polara1974 [ Tue Mar 01, 2016 12:05 pm ] |
Suscribed!!! Great Drag Caryou have there!!! |
| Author: | Greg Ondayko [ Tue Mar 01, 2016 2:02 pm ] |
Thanks, We'll see what it does this weekend if track is open. Greg |
| Author: | Greg Ondayko [ Sun Apr 24, 2016 6:48 pm ] |
| Post subject: | Spring 2016 Update 4-24-16 |
Today Was the 3rd Attempt that I had made since Re assembling the transmission with Aluminum Parts and A full roller Setup. It also has a lower first gear than stock. The First and second attempts out I had quite a bit of trouble with the trans actually shifting to 3rd gear consistently. I chased my tail adjusting the shifter cable and it was not that. It's something in the valvebody - Which I had used since 2009 with no problems. But for some reason after this rebuild and re assemble it's not acting the same - I think I will be getting a new one soon, but for now This one seems to be working for the meantime. I made 5 passes today at Keystone Raceway (Used to Be Pittsburgh Raceway park) The track management changed the name back to the 1960's-1990's name. The Megasquirt was breaking up a bit at the top end - But I was able to tune that out after a few passes. So was able to make a few respectable passes with the Barometer About 1.0 - 1.5 Lower than the Fall 2015 Race when I posted my best times. I noticed that my 60' Time is a few 100'ths Slower than my all time best - That could be attributed to the air or the other converter that I have been running last year and this year. Here's The rundown: Pass#4: 1.65 60' 7.56 1/8 Mile 11.9389 @ 110.40 1/4 Mile Pass#5 1.65 60' 7.57 1/8 Mile 11.9518 @ 111.39 1/4 Mile So I think that at a low elevation / Fast track in early spring or fall, I could pick up another 2 tenths. New Slicks could also support the cause. New Valve body or upgrade to trans brake from A&A Transmission Will be ordered as well. Greg |
| Author: | Dart270 [ Mon Apr 25, 2016 2:30 am ] |
Congrats on figuring out the trans issues. Nice to see some 11s slips there! RUSTAAAHHHHH! Lou |
| Author: | bmimken [ Mon Apr 25, 2016 6:26 am ] |
Awesome!!!! Brian |
| Author: | Polara1974 [ Mon Apr 25, 2016 7:08 am ] |
Most impressive!!!!!! Congratulations!!!!!!!! |
| Author: | Ron Hamby [ Mon Apr 25, 2016 7:50 am ] |
Greg congrats on getting the new tranny to do its thing. Times look good and very consistent. Is this the first time you have used the Transbrake? See you in M-D. Ron |
| Page 66 of 92 | All times are UTC-07:00 |
