It is currently Wed Nov 25, 2026 5:27 am
PostPosted: Wed Aug 11, 2004 1:21 am
Can you buy sure grip units and different gears new? I have a 7 1/4 rear, i'm not sure what gears are in it. I don't know what all the #s mean on my fender tag, can you help?
68 Valiant
http://www.oldvictoria.com/Cruise2004/target12.html
PostPosted: Wed Aug 11, 2004 5:12 am
Gears, yes. Randy's Ring and Pinion, had gears available. In fact they recently had a special on 4.10 gears.
Suregrip, I don't know of any, but check with Randy's, they also have axel shafts listed in an ad.
 Post subject: 7 1/4
PostPosted: Wed Aug 11, 2004 2:31 pm
Charlie, the 7 1/4 guru!! im going to buy some 4:10's, master bearing kit and new wheel bearings for my 63 signet. do you have any preference to brand(seems to be several-priced about the same). also and hints or suggestions on this job(im putting in my suregrip unit too) :o ??? thnx,steve
PostPosted: Wed Aug 11, 2004 2:51 pm
When I did my rears, most all the parts were good quality. I would try to get bearings that are not made in a third world country. Try to stay with a brand name. Set the pinion depth with a guage, and keep the backlash, on the minimum side, of the spec. Bearing preload is critical, so don't get slopy here. When done, get your work with a tooth pattern check.
PostPosted: Wed Aug 11, 2004 2:52 pm
When I did my rears, most all the parts were good quality. I would try to get bearings that are not made in a third world country. Try to stay with a brand name. Set the pinion depth with a guage, and keep the backlash, on the minimum side, of the spec. Bearing preload is critical, so don't get slopy here. When done, check your work with a tooth pattern check.
PostPosted: Wed Aug 11, 2004 3:34 pm
Charlie, where does one even get bearings made in a first-world country anymore? Seems any bearing or seal I buy anymore sez "CHINA" or "TAIWAN" (second-world countries?) on it, even NAPA stuff. Where can you get good ole' US of A (or Canada) bearings :?:
D/W
If it ain't broke, fix it!
PostPosted: Thu Aug 12, 2004 6:01 am
I havn't bought bearings in quite a while. SKF brand use to be good, but so were a lot of other product/brands.
