| short question on 71/4 rears https://slantsix.org/forum/viewtopic.php?t=10077 |
| Author: | KickiN 68 Valiant [ Wed Aug 11, 2004 1:21 am ] |
| Post subject: | short question on 71/4 rears |
Can you buy sure grip units and different gears new? I have a 7 1/4 rear, i'm not sure what gears are in it. I don't know what all the #s mean on my fender tag, can you help? |
| Author: | Charrlie_S [ Wed Aug 11, 2004 5:12 am ] |
Gears, yes. Randy's Ring and Pinion, had gears available. In fact they recently had a special on 4.10 gears. Suregrip, I don't know of any, but check with Randy's, they also have axel shafts listed in an ad. |
| Author: | mightyss [ Wed Aug 11, 2004 2:31 pm ] |
| Post subject: | 7 1/4 |
Charlie, the 7 1/4 guru!! im going to buy some 4:10's, master bearing kit and new wheel bearings for my 63 signet. do you have any preference to brand(seems to be several-priced about the same). also and hints or suggestions on this job(im putting in my suregrip unit too) |
| Author: | Charrlie_S [ Wed Aug 11, 2004 2:51 pm ] |
When I did my rears, most all the parts were good quality. I would try to get bearings that are not made in a third world country. Try to stay with a brand name. Set the pinion depth with a guage, and keep the backlash, on the minimum side, of the spec. Bearing preload is critical, so don't get slopy here. When done, get your work with a tooth pattern check. |
| Author: | Charrlie_S [ Wed Aug 11, 2004 2:52 pm ] |
When I did my rears, most all the parts were good quality. I would try to get bearings that are not made in a third world country. Try to stay with a brand name. Set the pinion depth with a guage, and keep the backlash, on the minimum side, of the spec. Bearing preload is critical, so don't get slopy here. When done, check your work with a tooth pattern check. |
| Author: | Dennis Weaver [ Wed Aug 11, 2004 3:34 pm ] |
Charlie, where does one even get bearings made in a first-world country anymore? Seems any bearing or seal I buy anymore sez "CHINA" or "TAIWAN" (second-world countries?) on it, even NAPA stuff. Where can you get good ole' US of A (or Canada) bearings D/W |
| Author: | Charrlie_S [ Thu Aug 12, 2004 6:01 am ] |
I havn't bought bearings in quite a while. SKF brand use to be good, but so were a lot of other product/brands. |
