It is currently Tue May 05, 2026 1:25 am
 Post subject: Drive shaft for 64 Dart
PostPosted: Sat Nov 06, 2004 2:10 am
I'm looking to replace my driveshaft with the original CV boot. Anyone know where I can get an original with a CV boot to replace it or get it worked so I don't have to replace it with a new state of the art crap.
 Post subject: drive shaft r/r
PostPosted: Sat Nov 06, 2004 3:12 am
another member used state-of-the-art cv joint boot, not sure which parts store but they had a similar sized one. Otherwise you are at the mercy of E-bay, they usually sell in a complete kit for $95+. Good Luck
PostPosted: Sat Nov 06, 2004 10:29 am
Anyone know what danger there is running the car with a damaged boot?
Also, if I install a '73 8 1/4 sure grip, do I need to change the driveshaft?
Thanks 8)
"Nothing in all creation is hidden from God's sight. Everything is uncovered and laid bare before the eyes of Him to whom we must give account."
PostPosted: Sat Nov 06, 2004 12:02 pm
1. A damaged boot will allow the ball-and-trunion grease to become contaminated and eventually fail.
2. The 8 1/4 differential is different in length from the axle centerline to the yoke. You'll need to have the driveshaft shortened. That might be a good time to have a driveshaft made to eliminate the B&T with a U-joint. See http://www.earlycuda.org/tech/ujoint.htm
PostPosted: Sat Nov 06, 2004 3:50 pm
The BT boot should be available from any good driveline shop. Spicer stills make rebuild kits for the BT.
PostPosted: Sun Nov 07, 2004 11:05 pm
thanks for the info. How about getting a '73 driveshaft for the "spicer type" conversion? Would that save any time or money?
Users browsing this forum: Amazon [Bot] and 1 guest
