It is currently Sun Nov 29, 2026 1:54 am
 Post subject: Exhaust Manifold
PostPosted: Sat Dec 04, 2004 11:17 pm
When I rebuilt my 225 I sandblasted the exhaust manifold and painted it with 1200 degree paint. It looked great for a short time but now the rust is starting to show through again. Would powder coating be a good option or is there something out there I could use that would last longer than regular paint?
70 Valiant Super Six
PostPosted: Sun Dec 05, 2004 9:20 am
There is a special powder coating that is made for high heat applications, it works well.
Jet Hot is the most well known but there are other suppliers.
I have used this type of coating and it looks great, the only problem is that the "chrome silver" color gets a little dull looking over time.
PostPosted: Sun Dec 05, 2004 12:17 pm
ooOOOOooo...those Dutra Duals look way sexy with Jet Hot on 'em. What'd it cost to have it done, and what kind of prepwork did you have to do? Is this coating thick enough that it fills in the surface pits and irregularities of cast iron, or did you have to manually smooth it before sending 'em in?
PostPosted: Sun Dec 05, 2004 8:54 pm
Doc, is the picture you posted a set? The article on Dutra Duals shows one side with a place for the intake to bolt to. Is that not really necessary? Removing that part of the exhaust manifold would sure alleviate a possible exhaust leak from that mating surface. Also, where do you get Jet Hot and how do you prepare the surface?
PostPosted: Mon Dec 06, 2004 9:01 am
The photo is of a "Dual Dutra Duals" set where I machine new Dutra castings to fit the front and rear of the engine. Using dual Dutra Duals eliminates the carb heat and the automatic choke provisions.
For a street car, using the modified factory manifold to service the rear 3 cylinders is the way to go but if you are after full flow / good looks and don't give a hoot about cold engine operation "manners" then dual Duals is the ticket.
As for the high heat coating, I do spend a little extra time on prep for the manifolds I coat. I get out all the parting lines and deep "pits". The coating does go on thick so it blends-in a lot of the cast iron surface grains.
I use a coater here in the Bay Area, they charge me about $130.00 per set (2 manifolds)
PostPosted: Mon Dec 06, 2004 10:41 am
You can always get intake manifold heat by running hot water from the heater's return line to the base of your intake manifold. You won't miss the choke well in the exhaust manifold if your carb has an electric choke or if you convert to a manual choke.
If you don't want to make one, I have a ready-made kit: http://cars.rasoenterprises.com/Products-Mopar.htm
Frank
PostPosted: Mon Dec 06, 2004 5:17 pm
Hey, Frank, didn't realise you're in ON!
Where's Stevensville?
PostPosted: Mon Dec 06, 2004 6:17 pm
I have found some stuff that works great. Although it is probably not accesible to everyone. I work in the chlor-alkili industry and we coat our cells with a rust inhibitor that is as tuff as nails. It goes on kind of milky and the hotter it gets it turns blacker. It stays a nice black color and is impervious to most everything. Hey, if it will stand up to caustic soda, it's pretty damn tuff. I'll get the name of it, maybe it's available somewhere. It worked very well on my exhaust.
PostPosted: Tue Dec 07, 2004 5:54 am
Checkout www.techlinecoatings.com they have a list of applicators for their products. You can probably find one near you. They can apply different layers to drastically cut under hood temps.
Jet-Hot are the only ones I know of that will warrantee their work for 3 yrs and are a very good choice as well.
All exhaust coatings are a liquid coating(to my knowledge). It is basically a ceramic coating that will withstand temperatures in excess of 1500 degrees. It requires a higher temp cure cycle than powder. I do not know of a powder that is made for anything above about 500. They do sell powders for BBQ grills but these are not formulated to hold up above 500 surface temp.
Hoosier - I would like to find out what the stuff is you use a work. Sounds interesting. Is is a thermal barrier type coating or just a corrosion inhibitor?
Tom
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Tue Dec 07, 2004 6:18 am
Dan,
Stevensville is part of greater Fort Erie and Fort Erie is just across the river from Buffalo, NY. We've got one traffic light but no Tim Horton's.
Frank
PostPosted: Tue Dec 07, 2004 8:55 am
Well, shoot, you're only about an hour away from me! I'm in Tronna. In a few years when the daylight lasts longer than 4 hours and it rises above -40° (OK, at least it feels like it's going to be a few years) we should get together. I read your stuff years ago in the \6 News, and I'd surely like to see your car in person!
PostPosted: Tue Dec 07, 2004 10:31 am
That would be great. I've taken my Barracuda off the road for the winter now and am just putting a new gas tank in my 73 Dart so I can drive it through the winter. I'm even feeling ambitious enough to fix the front seal and put in a new timing chain in the Dart. I have an interview coming up at Lear in Mississauga tomorrow so I'm making sure that it's up for some serious commuting. No plans to change to a Rochester 2bbl or an SU though. The 1bbl is staying on it until the wheels fall off!
Frank
PostPosted: Tue Dec 07, 2004 11:55 am
Tom-
I have my headers coated with a 'high temp' powder coat. Supposed to hold up to 1300*. I had them coated locally, the supplier said it was a generic type of Jet-hot, but was definitely still powder-coat.
Seems to be holding up well thus far, no signs of blistering, burning, etc. And is also holding up to rock chips very well (down by the low-hanging collectors).
<img src='http://img.villagephotos.com/p/2004-10/860264/EngineBayDriver.jpeg' width=400>
-S/6
PostPosted: Tue Dec 07, 2004 12:20 pm
Tom
I also used the Tech Line coating Black Saturn (P/N 1012, $45 for 12oz.) from Tech Line Coatings, Inc. on the exhaust side of my turbo as well as on the up and down pipes that I fabricated. I'll eventually put this coating on my exhaust manifold as well. This stuff retains heat better than powder coatings. With a turbo the goal is to retain as much of the heat in the exhaust as possible. Tach Line Coatings Inc. does not recommend the use of a brush, and the coating is most effective when applied in a very thin coat. It has been on for two years now and still looks almost as good as in this picture. http://hometown.aol.com/bbobbias/page1.html
It's expensive, but the 12oz. is probably enough to do 12 manifolds.
Bob D
PostPosted: Tue Dec 07, 2004 12:38 pm
I have used techlines coating(black satin, msb and few others) and everything they sell is in a liquid form. Morton makes what they call high temp black in powder form but it is not intend for anything over about 500-600 surface temp and does not contain ceramic like most exhaust coatings. This may be what they applied to you headers but I doubt it would hold up very long. Jet-Hot is liquid not powder. The ceramic in the exhuast coatings will not work like powder.
If it is a powder then I would like to know who manufactures it. Dupont, Tiger Drylac, Morton...etc do not show any powders for exhaust coatings.
Tom
FJD
