It is currently Sat Nov 28, 2026 10:34 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Thu Dec 09, 2004 12:41 pm
I am new owner of SS truck and new to this forum. I am trying to post this to the general forum to get more response?
My Super Six appears to have had a Carter BBD type 2-Brl. carb. put on it and I have many "loose ends":
-2 3/8 vacuum lines from brake cannister #4227-010 at grill. My vacuum diagram says these 2 vacuum lines should go to "base of my carb". The beforementioned carb. has no base????What to do?
-I have cluster of 4-6 1/16 inch. plastic vacuum lines coming of rear firewall? Do these work with my dash controls?
-I want to dis-connect my EGR and Air pump as I have no emissions in my county. Do I get a smaller belts after removing air pump or simply leave unit and disconnect my hoses?
-On my valve cover, I have:
(1) PCV valve goes to back of carburetor. Could I tee off these to run that vacuum cannister's lines? and
(2) Breather "cap" which goes no-where? 3/4 inch. hose. Where should it go?
I need specific info. on this BBD carb. because the choke valve does not operate correctly (no spring tension - always open....tampered with!).
Pls. advise where you can. Thanks in advance for help.
Larry
PostPosted: Thu Dec 09, 2004 1:34 pm
Whoah there.
1987 D150s did not have a "Super Six" (=225 with a 2bbl carb) available as an option. So, somebody has swapped on the 2bbl setup from another vehicle. The Super Six setup did use a Carter BBD.
There is no "brake cannister" at the grill. There is an evaporative emission control canister located at the right front corner of the engine compartment; it has nothing to do with the brakes.
That is not correct. One of them is a combined vent line for the fuel tank and carb bowl vents, and the other is the purge line that does connect to the "base" of the carb, sometimes via the PCV main line.
Um...yeah, it does. All carburetors have bases.
You really need a factory service manual.
Disconnecting your air pump will cook your catalytic converter.
Yes, but you MUST tee the correct line in. Guessing won't get the job done.
To the matching fitting on the air cleaner housing.
Needs a new choke thermostat.
PostPosted: Thu Dec 09, 2004 1:49 pm
I have had my air pump disconnected for almost a year and it still runs good. I throw a belt on it for inspection.
PostPosted: Thu Dec 09, 2004 2:08 pm
When you say "at the grill", are you referring to the EVAP charcoal canister (located where Dan stated) or are you referring to the emissions decal near the grill that shows basic vacuum routing?
Directly above, and roughly centered over the HVAC box there is a plug going through the firewall with two small (1/16" sounds right) vacuum lines running through it. These two lines control the air doors in the HVAC box. Does your truck have/had A/C? If A/C equipped there is a 'vacuum block' (for lack of a better term) on the passenger fender well that may have as many as 4 vacuum lines running to it. I never figured out the purpose of this 'block' except as an additional spot for vacuum leaks. But then, the A/C never worked in my truck since I owned it either. :?
If you have A/C, the same belt runs both the A/C compressor and the AIR pump. IIRC a smaller belt will not fit around the crank and A/C compressor after removing the AIR pump, as the waterpump pulley will be in the way. :( You would either (1) have to make an idler pulley where the smog pump was, or (2) relocate the A/C compressor.
No A/C....just remove the belt. EGR: Either you can fab up a block-off plate to bolt in place of the EGR valve, or you can simply unbolt the EGR valve, rotate it 180*, and bolt it back on. Doing so disables the EGR valve. i wouldn't worry about the cat(s). I ran around for 4 years with no Air pump and never melted either catalytic converter (Your truck may have one or two cats. One will be under the truck, roughly right under the cab. If you have two, the second one is directly off the exhaust manifold, and the AIR pump piping is routed into this upstream cat).
Check out the Articles section under "Supersix" by Reed Speir for info on the Carter BBD.
Your power brake booster (large pancake shaped vacuum booster behind the master cylinder) should have one large vacuum line (3/8" ?) running to the vacuum 'tree' on the #6 intake runner. Your two heater air-door control vacuum lines also connect to the small nipples on this vacuum tree.
Does the truck still have lean burn ignition (computer behind battery) or has it been converted to electronic ignition or other? (See my post at ss.com to identify ignition)
-S/6
PostPosted: Thu Dec 09, 2004 5:24 pm
not to hijack larrys thread, but when i switched to a bbd 2 bbl on my '86 stepside, i capped off all the vacuum ports not needed on the carb since our smog program was scrapped also :mrgreen: . only the 'timed' port (on the choke side of the carb) for the distributor, the choke pull-off, and the pcv port were the only ones used. the brake booster was hooked to the manifold vac tree, and the charcol canister was disabled and removed along with the bowl vent tube on the carb.
i did 86'ed the lame burn computer and replaced the distributor with a '72 points unit that was outfitted with the pertronix ignitor (part # 1361-a). this proved to be less expensive than the mp conversion kit and much easier to install (no cutting and splicing :mrgreen:)
with everything done, i couldnt believe the improvement. on a trip to an amc/mopar meet in texas, some 360 miles from home, the truck was getting 22 mpg cruising at 70 mph with the throttle just cracked open. good enuff for me 8)
as far as your choke, you can find a electric choke assembly from any super six equipped aspen. at a boneyard. get the choke control switch while your there.
also make sure the choke pull-off diaphram is working and not leaking down( an often overlooked source of a vacuum leak).
to test for leakdown, push in on the diaphram stem and hold the vacuum port closed with your fingers like a drinking straw. the stem should remain still. any movement of 1/16 or more over a ten second period and the choke pull-off diaphram needs replacing.
hope that helps a little. sorry for the long post :oops:
PostPosted: Thu Dec 09, 2004 5:31 pm
Disabling the charcoal cannister is pointless, counterproductive and dumb.
PostPosted: Thu Dec 09, 2004 5:36 pm
btw, i did scrap the smog pump and both cats, replacing it with 2 1/4 aluminized pipe and stock sound muffler from midas. she had to breathe :lol:
PostPosted: Thu Dec 09, 2004 5:41 pm
please explain why.
PostPosted: Thu Dec 09, 2004 5:48 pm
i didnt think so. the canister was cracked anyway, so why have the useless clutter under the hood?
there was a time when cars and trucks didn't run evaporation controls and i did mention that my town no longer has smog inspection :wink:
PostPosted: Thu Dec 09, 2004 5:51 pm
Amazing. Forty-four years after emission controls first appeared on vehicles, we still have people haphazardly disabling them just 'cause there's no inspection, and thinking that if a device's primary purpose is to reduce emissions, it must reduce performance.
Some real quick studies and bright sparks we got around these parts, you betchya.
PostPosted: Thu Dec 09, 2004 6:09 pm
Forty-four years after emission controls first appeared on vehicles??
40 years ago I could buy a hemi.. Try closer to 30 years
slantsixdan .... do you work for the government or something? remember before we had smog control on everything I could have bought a big block or a hemi (a real hemi not a new dodge marketing scheme) now I see a lot of Honda’s and Toyota’s ... before smog control we had hyper pac's... you run your converters and I will punch mine... since I ripped all that crap off my truck I got about 5mpg better that would lead me to think that I must be burning that gas I’m sucking into the cylinders instead of blowing air down the exhaust pipe to dilute the emissions coming out of the pipe. ... You see unburned fuel=low mpg=bad ... burned fuel=high mpg= good.
PostPosted: Thu Dec 09, 2004 6:32 pm
consider it a legacy living on: as long as there were emission controls there were always people disabling them as long as theres no inspections.
oh and faulty emission components WILL reduce performance. and replacement parts can get expensive. maybe the person is on a tight budget and needed the vehicle running but pronto. cut the person some slack and dont be so judgemental.
PostPosted: Thu Dec 09, 2004 8:11 pm
Sure, he was on a shoestring budget. Right.
Judgemental? You bet. When people do stupid stuff, I am inclined to squawk about it. Call me allergic to stupidity.
Disabling the charcoal cannister is tantamount to going to a gas station, shoving your credit card in the pump, pumping the gasoline onto the sidewalk and walking away. You pay for the gas, you never get to use it, and it goes into the air we all breathe. Stupid, stupid, stupid.
PostPosted: Thu Dec 09, 2004 8:20 pm
...and damn all those farmers for letting their cattle fart into our atmosphere! :roll: :lol: Wonder how much petroleum was used to make all those plastic charcoal canisters? :idea:
D/W
If it ain't broke, fix it!
PostPosted: Thu Dec 09, 2004 10:34 pm
:D
