It is currently Sun Nov 29, 2026 2:56 am
 Post subject: Heads and Bores
PostPosted: Thu Dec 09, 2004 1:31 pm
ive got a 65000 mile slant in the back yard that i might drop in my dart. i was talking to my brother about taking the head off and working it over a little bit.
he said he wasnt sure if that was a good idea because sometimes when the heads been on the motor and torqued down it distorts the bores just a bit. if you take the head off and put it back on, that it might cause the rings to not seat back quite as good because they have worn to the way the bore was distorted.
that might have been a little tough to understand with all my rambling but do you guys think this is something i should be worried about if i take the head off?
PostPosted: Thu Dec 09, 2004 2:15 pm
No. The biggest reason rings won't seal after a head swap is dirt in the bores. Keep it clean and you should be fine. :shock:
PostPosted: Thu Dec 09, 2004 2:22 pm
thanks, this motor swap might be happening relatively soon if my motor keeps on with its downhill slide.
if anyone else has an opinion on this subject, id love to hear from them.
thanks
PostPosted: Thu Dec 09, 2004 3:43 pm
The bore is definitely distorted from tightening the head bolts, but it will go back to it's original shape when re-assembled, and AFAIK even a different head won't change it - it's the bolts not the head casting.
You're safe - as slantzilla said keep it clean.
