It is currently Sat Nov 28, 2026 2:36 am
PostPosted: Wed Dec 15, 2004 10:37 am
74 Scamp with Holley 5200 which I believe is the same as the Weber 32/36 DGEV and Proline fuel adapter plate. Can someone explain how to set up the vac lines? I have an EGR valve and temp sensor in the radiator plus the sperical vaccum device (amplifier maybe?) Also there are two connections into the passenger compartment. Can someone send me a diagram or try to descibe how I should connect it up? Also the vacuum advace I believe goes to the carburetor but not sure where on this carburetor.
Sweet Emotion
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
