74 Scamp w/ Weber /Holley vac setup help?
https://slantsix.org/forum/viewtopic.php?t=11203
Page 1 of 1
Author:  textoad [ Wed Dec 15, 2004 10:37 am ]
Post subject:  74 Scamp w/ Weber /Holley vac setup help?
74 Scamp with Holley 5200 which I believe is the same as the Weber 32/36 DGEV and Proline fuel adapter plate. Can someone explain how to set up the vac lines? I have an EGR valve and temp sensor in the radiator plus the sperical vaccum device (amplifier maybe?) Also there are two connections into the passenger compartment. Can someone send me a diagram or try to descibe how I should connect it up? Also the vacuum advace I believe goes to the carburetor but not sure where on this carburetor.
Thanks
