It is currently Mon Nov 23, 2026 3:42 am
PostPosted: Fri Dec 17, 2004 6:53 pm
I recently purchaced a (very) low mile 68 sedan w/ slant 6. It has stock
13" rims. The spare still has the Goodyear 2 ply bias tire!
Can I get 14" steel rims for this car? I am not looking for performance
tires or racing ability. I just want a little more meat on the street.
 Post subject: wheel /tire change
PostPosted: Sat Dec 18, 2004 5:07 am
Yes, as long as you maintain the total height that ws designed for the car it doesn't matter what size wheel. I believe around 24-25" total is your height you need. A 205/70/14 is approx that size & will not change your speedo much. You can put taller/shorter combo's it just changes your original speedo accuracy. I had that size on my 69 dart with no problems.
PostPosted: Sat Dec 18, 2004 7:00 pm
There is a very good tire size site: http://www.miata.net/garage/tirecalc.html if you need to determine height and width from one size to another.
