It is currently Wed Oct 14, 2026 7:18 am
 Post subject: 7 1/4 axels
PostPosted: Sat Dec 18, 2004 4:50 am
ok, i remember something about the 7 1/4 changing axel size "3" times? i need to know what years for interchangeability for center sections and whatnot. ex., will a 69 center work w/a 63 housing and axels. thnx much................steve
 Post subject: axle stuff
PostPosted: Sat Dec 18, 2004 5:39 am
This was from an earlier post- from the good doctor, It will help
"The 60-62 (and even some early 63s) have a real small axle bearing that has been "NA" for some time now.
Here are some other numbers to search for:
New Departure # D88506FR
Also show RW206FFR and RW206CCR as listings.
If you run accross a later (64-72+) 7 1/4 rearend with the larger bearing axles, grab it along with the backing plates and think about swapping over to that (more common) set-up.
DD"
Hope that helps
PostPosted: Sun Dec 19, 2004 6:10 am
thnx vdart, so there were 2 sizes of axels? that narrows it down, hope mine 63 wasnt the "small" one..................................steve
PostPosted: Sun Dec 19, 2004 11:58 am
'73 and up disc brake cars had different axels too. They will definitly not interchange with an earlier housing. The center section should though. :D
