| 7 1/4 axels https://slantsix.org/forum/viewtopic.php?t=11227 |
| Author: | mightyss [ Sat Dec 18, 2004 4:50 am ] |
| Post subject: | 7 1/4 axels |
ok, i remember something about the 7 1/4 changing axel size "3" times? i need to know what years for interchangeability for center sections and whatnot. ex., will a 69 center work w/a 63 housing and axels. thnx much................steve |
| Author: | VDART [ Sat Dec 18, 2004 5:39 am ] |
| Post subject: | axle stuff |
This was from an earlier post- from the good doctor, It will help "The 60-62 (and even some early 63s) have a real small axle bearing that has been "NA" for some time now. Here are some other numbers to search for: New Departure # D88506FR Also show RW206FFR and RW206CCR as listings. If you run accross a later (64-72+) 7 1/4 rearend with the larger bearing axles, grab it along with the backing plates and think about swapping over to that (more common) set-up. DD" Hope that helps |
| Author: | mightyss [ Sun Dec 19, 2004 6:10 am ] |
thnx vdart, so there were 2 sizes of axels? that narrows it down, hope mine 63 wasnt the "small" one..................................steve |
| Author: | slantzilla [ Sun Dec 19, 2004 11:58 am ] |
'73 and up disc brake cars had different axels too. They will definitly not interchange with an earlier housing. The center section should though. |
