It is currently Tue Oct 13, 2026 7:50 pm
 Post subject: Lost my reverse!
PostPosted: Mon Dec 27, 2004 8:30 pm
I have a 73 valiant,auto trans 904 and I was buried in the snow and had to rock the car back and forth,drive,reverse,etc. and my reverse stopped working! How bad is this?Any help would be appreciated! thanks! :shock:
PostPosted: Mon Dec 27, 2004 9:57 pm
If the forward gears, still work OK, you probably broke the first/reverse band, or strut.
PostPosted: Tue Dec 28, 2004 8:57 pm
Sounds like it is time to drop the trans pan and have a look inside.
It could be that a simple band adjustment will fix the problem or as Charrlie_S suggested, the rear band is broken and it will need to be replaced.
One other possibility is that the rear band servo piston seals are worn / torn or leaking. These can be replaced without removing the trans.
PostPosted: Wed Dec 29, 2004 6:27 am
DD. I'm thinking, since he was rocking the car, between forward and reverse, the band broke. The other possibility is , if the rear band was loose, the strut might have popped out. If it is the strut, it might be possible to get it back in, with a lot of patience. Then readjust it correctly. But I agree, time to drop the pan and have a look.
PostPosted: Wed Dec 29, 2004 12:40 pm
I vote for a broken reverse band. Back when I was young and stupid I wondered what would happen if I put my Valiant in reverse when I was going down the road forware at a slow speed. Well.... I just killed the engine that day. A few weeks later as I was backing up I hear a BANG !! and I had no more reverse. Yes it was a broken reverse band.
Look for a dent in the bottom of the transmission pan.... from the inside out........ when the band broke, some lever inside was free to dent the pan from the inside.
PostPosted: Wed Dec 29, 2004 5:03 pm
If you try driving downhill in 1st. Does the engine try to hold the car?(engine brake) or does it just roll like in neutral?
Anyway I think you have to open it up and have a look.
PostPosted: Thu Dec 30, 2004 6:24 am
definitely pull the pan.
Check for three things:
Low/reverse band looseness or breakage
Band apply strut damage or mis-location
Sticking low/reverse servo assembly (you may need a C-clamp to check this, space permitting)
