| Lost my reverse! https://slantsix.org/forum/viewtopic.php?t=11293 |
| Author: | nflm65 [ Mon Dec 27, 2004 8:30 pm ] |
| Post subject: | Lost my reverse! |
I have a 73 valiant,auto trans 904 and I was buried in the snow and had to rock the car back and forth,drive,reverse,etc. and my reverse stopped working! How bad is this?Any help would be appreciated! thanks! |
| Author: | Charrlie_S [ Mon Dec 27, 2004 9:57 pm ] |
If the forward gears, still work OK, you probably broke the first/reverse band, or strut. |
| Author: | Doctor Dodge [ Tue Dec 28, 2004 8:57 pm ] |
Quote: If the forward gears, still work OK, you probably broke the first/reverse band, or strut.
Sounds like it is time to drop the trans pan and have a look inside.It could be that a simple band adjustment will fix the problem or as Charrlie_S suggested, the rear band is broken and it will need to be replaced. One other possibility is that the rear band servo piston seals are worn / torn or leaking. These can be replaced without removing the trans. DD |
| Author: | Charrlie_S [ Wed Dec 29, 2004 6:27 am ] |
DD. I'm thinking, since he was rocking the car, between forward and reverse, the band broke. The other possibility is , if the rear band was loose, the strut might have popped out. If it is the strut, it might be possible to get it back in, with a lot of patience. Then readjust it correctly. But I agree, time to drop the pan and have a look. |
| Author: | Craig [ Wed Dec 29, 2004 12:40 pm ] |
I vote for a broken reverse band. Back when I was young and stupid I wondered what would happen if I put my Valiant in reverse when I was going down the road forware at a slow speed. Well.... I just killed the engine that day. A few weeks later as I was backing up I hear a BANG !! and I had no more reverse. Yes it was a broken reverse band. Look for a dent in the bottom of the transmission pan.... from the inside out........ when the band broke, some lever inside was free to dent the pan from the inside. |
| Author: | Rust collector [ Wed Dec 29, 2004 5:03 pm ] |
If you try driving downhill in 1st. Does the engine try to hold the car?(engine brake) or does it just roll like in neutral? Anyway I think you have to open it up and have a look. |
| Author: | cbe10581 [ Thu Dec 30, 2004 6:24 am ] |
definitely pull the pan. Check for three things: Low/reverse band looseness or breakage Band apply strut damage or mis-location Sticking low/reverse servo assembly (you may need a C-clamp to check this, space permitting) |
