It is currently Sun Nov 22, 2026 6:52 pm
PostPosted: Thu Jan 06, 2005 8:05 pm
Assuming I have the car high enough, and using the floor jack to lower the rear end to get access to the spring bushings
My question is: Should I be concerned with anything torquing as I lower
the assembly.
Should I lower one side at a time or both? I don't want to have anything
twist out of alignment preventing me from raising the assembly to bolt it back onto the frame?
Thanks for any replies.
Matt
[/i]
67 Dart GT convertible
"225 Slant 6"
Super 6 and 2.25" exhaust.
PostPosted: Fri Jan 07, 2005 7:52 am
If the front bushings and springs are in good shape it is pretty easy. Lots of times the shackle bolts snap. Poly bushings can be a tight fit,,,use lots of lube. I do one side at a time. The shackle design is kinda self aligning.
