| Question on Installing rear shackle bushings https://slantsix.org/forum/viewtopic.php?t=11370 |
| Author: | Mguesto [ Thu Jan 06, 2005 8:05 pm ] |
| Post subject: | Question on Installing rear shackle bushings |
Assuming I have the car high enough, and using the floor jack to lower the rear end to get access to the spring bushings My question is: Should I be concerned with anything torquing as I lower the assembly. Should I lower one side at a time or both? I don't want to have anything twist out of alignment preventing me from raising the assembly to bolt it back onto the frame? Thanks for any replies. Matt [/i] |
| Author: | sandy in BC [ Fri Jan 07, 2005 7:52 am ] |
If the front bushings and springs are in good shape it is pretty easy. Lots of times the shackle bolts snap. Poly bushings can be a tight fit,,,use lots of lube. I do one side at a time. The shackle design is kinda self aligning. |
