It is currently Tue May 19, 2026 5:36 am
 Post subject: 8.25 carrier ID
PostPosted: Mon Jan 10, 2005 7:41 pm
I copied this from an old post:
Duster Idiot wrote:
The 2.45/2.24 carriers are different (I 've seen one's that looked narrower/skinnier) and will not accept the 2.76 and higher ratio ring gears....The fix for that is to pull a carrier races and ring and pinion out of a car/truck and install into your 2.45 or worse axle housing.... (Of course I'd like to see one of the 'Sure Grip' 2.45's that was possible to get from 1973-1976....boy, that'd be a real screamer....).
Is there a way to ID the different carriers externally? Or do you have to figure out what gears you have, and if you find that they are 2.45/2.24 then you are S.O.L.?
Jay
