It is currently Fri Nov 20, 2026 5:23 pm
 Post subject: And for the rest of us
PostPosted: Wed Feb 02, 2005 2:17 pm
For those of us who didn't read that can you enlighten us? Are you saying any old F or J body spindels can be used to upgrade to fron disk brakes?
PostPosted: Wed Feb 02, 2005 3:49 pm
Yes!
(if you subscribe to the theory that the non a-e body spindle doesn't screw up the front suspension geometry too much)!
For a street car the non a-body spindle works fine.
'68signet
"Living analog in the digital age."
PostPosted: Wed Feb 02, 2005 7:38 pm
there are also others that believe the non A-body spindles are better, personally I'm running other body spindles and have had no problem and I ride the suspension hard at times, more so than many people because I believe it's important to know how to use your car. I seriousely doubt that you could tell the difference in handling between the two spindles, but I wouldn't shy away from using other body spindles.
As for the article, check out
www.bigblockdart.com
there's another one that is against using other body spindles, I can't remember it's URL, personally I would read both of them before making any decisions(and read anything else you can get your hands on). I can endorse all I like, but I admit I haven't done any scientific testing, these articles have or at least know more about suspension then I do.
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
