truck trans. ?
https://slantsix.org/forum/viewtopic.php?t=11692
Author:  \6T [ Wed Feb 09, 2005 8:29 pm ]
Post subject:  truck trans. ?
I am building a street rod using a slant from a 74 dodge 1/2 ton pick up.
The trans. is one I do not recognize. it is a top loader with column shift
linkage and an odd third lever on the side of the case that would appear
to be some sort of reveres lock out, or a device to prevent the
engagement of two gears at once (not all that uncommon with worn
linkage. Can anyone tell me what trans. this is, and can I get a shorter
tail shaft and housing? It has no boss for a floor shifter on the tail stock
as I have seen on most MoPars of that period
Thanks in advance \6T
Author:  Guest [ Wed Mar 02, 2005 7:46 pm ]
I think thats a heavy duty truck trans with the low creeper first gear,the other(not top loaders) 4spd in trucks were the same as the ones that were put in the car,this is the kind thats in my truck an 83,150,I'm not sure if the top loader is trans you would want in a car,some one else with more info should chime in ,,,speedfreak
Author:  Guest [ Wed Mar 02, 2005 7:53 pm ]
also check this page out /slantsix.org/articles/4speed/ODA833fourspeed1.htm WOW its been a month since this posted,hope you see this,,,speedfreak.
