It is currently Fri Nov 20, 2026 12:04 am
 Post subject: short trans.
PostPosted: Sun Feb 20, 2005 1:01 pm
What is the shortest bellhousing trans combination I can use behind a 225 six. I'm having trouble getting enough room for a driveshaft, 2' is not enough. The three speed manual box I have is 34 inches from bellhousing to engine flange to end of tail shaft. I need a answer quick!! Standard or automatic is OK.
\6T
PostPosted: Sun Feb 20, 2005 1:47 pm
Hi
That should be 2" is not enough, 2' would be fine.
Sorry
\6T
PostPosted: Tue Feb 22, 2005 3:44 pm
The shortest combination is a /6 bellhousing with a A or F body transmission.
JZ
PostPosted: Tue Feb 22, 2005 4:32 pm
Slant six engine, slant six 727 trans with a shorty tailshaft kit. The tailshaft was less then 6 inches long. You will have to be very carefull about driveshaft lenght. The depth of engagement is much more critical then with a standard tailshaft. Some trucks had short tail transmissions, But Fairbanks racing trans (no longer in speed business) and B&M use to have an racing unit, which was shorter yet. You could try Pat Blais Transmissions. tflitepatty@verizon.net They might know if it is still available.
Just went out to the shop and measured a shorty trans. The total lenght of the trans from engine mounting surface to back of tail housing is 21 inches.
PostPosted: Fri Feb 25, 2005 7:43 am
HI,
Thanks for the reply. The short (21") transmission you mentioned, is that a 727? Does that have the after market tail housing you mentioned? The 3spd box I have is short only about 8 ' but the tail stock is extra long over all length 34 "
\6T Thanks
PostPosted: Fri Feb 25, 2005 9:46 am
Yes, the shorty trans, is a 727 with a aftermarket tailshaft kit. I don't know if the shorty kit is still available or not. The were popular in the 60's and 70's.
PostPosted: Fri Feb 25, 2005 12:15 pm
http://board.moparts.org/ubbthreads/sho ... =7&fpart=1 :shock:
