| short trans. https://slantsix.org/forum/viewtopic.php?t=11820 |
| Author: | \6T [ Sun Feb 20, 2005 1:01 pm ] |
| Post subject: | short trans. |
What is the shortest bellhousing trans combination I can use behind a 225 six. I'm having trouble getting enough room for a driveshaft, 2' is not enough. The three speed manual box I have is 34 inches from bellhousing to engine flange to end of tail shaft. I need a answer quick!! Standard or automatic is OK. Thanks \6T |
| Author: | sandy in BC [ Sun Feb 20, 2005 1:47 pm ] |
Hi That should be 2" is not enough, 2' would be fine. Sorry \6T |
| Author: | Johnny Z [ Tue Feb 22, 2005 3:44 pm ] |
The shortest combination is a /6 bellhousing with a A or F body transmission. JZ |
| Author: | Charrlie_S [ Tue Feb 22, 2005 4:32 pm ] |
Slant six engine, slant six 727 trans with a shorty tailshaft kit. The tailshaft was less then 6 inches long. You will have to be very carefull about driveshaft lenght. The depth of engagement is much more critical then with a standard tailshaft. Some trucks had short tail transmissions, But Fairbanks racing trans (no longer in speed business) and B&M use to have an racing unit, which was shorter yet. You could try Pat Blais Transmissions. tflitepatty@verizon.net They might know if it is still available. Just went out to the shop and measured a shorty trans. The total lenght of the trans from engine mounting surface to back of tail housing is 21 inches. |
| Author: | \6T [ Fri Feb 25, 2005 7:43 am ] |
HI, Thanks for the reply. The short (21") transmission you mentioned, is that a 727? Does that have the after market tail housing you mentioned? The 3spd box I have is short only about 8 ' but the tail stock is extra long over all length 34 " \6T Thanks |
| Author: | Charrlie_S [ Fri Feb 25, 2005 9:46 am ] |
Yes, the shorty trans, is a 727 with a aftermarket tailshaft kit. I don't know if the shorty kit is still available or not. The were popular in the 60's and 70's. |
| Author: | slantzilla [ Fri Feb 25, 2005 12:15 pm ] |
http://board.moparts.org/ubbthreads/sho ... =7&fpart=1 |
