It is currently Sat Sep 19, 2026 4:23 am
 Post subject: What bolts are required?
PostPosted: Sun Feb 20, 2005 7:57 pm
Two years ago, we seem to have not separated and labled very well the bolts mounting the A-904 auto tranny to the slant six. Can someone tell me the sizes and placement of the necessary bolts?
Thanks,
Jerry
PostPosted: Sun Feb 20, 2005 11:08 pm
Two 7/16 - 14 unc bolts (5/8 Hex head) that go in thru the block at each lower side and thread into the trans bellhousing.
Four 3/8 - 16 unc bolts (9/16 Hex head) that go thru the bellhousing and thread into the engine block. (one of them is a little longer and goes thru the block and threads into the trans bell, just above the starter.
PostPosted: Mon Feb 21, 2005 10:35 am
Perfect, Doc, just what I needed. Now we can go throught our bags of bolts and look for those you described. I appreciate the help.
Jerry
