It is currently Sun Nov 22, 2026 7:43 am
PostPosted: Mon Sep 04, 2006 7:43 pm
Gents,
I have been working on a 82 D150. The lean burn system is gone and
a new electronic ignition is in its place. As I have been following your
advice as a group on this restore, I pulled the carb off ( two barrel
Carter BBD) to rebuild since it was leaking like a bear. It has a rebuilt
sticker on it now. My question is are there any things I have to look for
in the body to determine if the carb is still worth re-rebuilding properly?
I was very happy to learn that it had a Carter BBD after reading all
the bad stuff about the Holley 1 and 2 barrels. ( Though I think the
Holley 2 barrel might have been ok too. Just not as good as the Carter
from what you guys have written)
Thanks in advance.
Chuck
PostPosted: Mon Sep 04, 2006 8:46 pm
Examine the carb with extreme prejudice. Often the damage done during a factory "remanufacturing" is not practically reversible.
