It is currently Sat Nov 21, 2026 3:30 am
 Post subject: kickdown trouble??
PostPosted: Thu Mar 17, 2005 12:19 am
i had to bend my kickdown linkage toward the front of the car a couple of degrees to clear the header. this has seem to effect the way the car shifts and i dont understand why. anyone know?
1975 Dart Swinger 225 2bbl
PostPosted: Thu Mar 17, 2005 4:11 am
if you bent the rod you have changed the length of it...readjust it....at wide open throttle the rod should be all the way back against the stop in trans
