It is currently Fri Nov 20, 2026 5:37 pm
PostPosted: Thu Mar 17, 2005 11:08 am
Hi,
I"m doing a 65 valiant rebuild.The K-frame is cracked around the strut bushing on the passenger side.I was thinking about welding it.Anyone have any ideas? I have a 65 parts car and was going to swap the k-frame but it has the same problem (cracked on the passenger side)I'm sure this is a pretty common problem.
thanks for all :?: your help in advance
PostPosted: Sat Mar 26, 2005 10:07 pm
Site Admin
Just grind it clean and weld it up. Make sure the surface where the bushing sits is smooth if you are using the Moog bushings.
Chuck Rivers, Webmaster
Image Image Image Image
