It is currently Thu Jan 01, 2026 6:27 am
 Post subject: no smoke
PostPosted: Mon Apr 04, 2005 12:52 am
have 2 cylinders that are oil fouling the plugs. what i don't understand is, at no time does the engine smoke. shouldn't it smoke as the plugs are beginning to foul? compression is 145 lbs give or take 5 lbs all cyl.
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
 Post subject: Re: no smoke
PostPosted: Mon Apr 04, 2005 4:23 am
Sure it doesn't smoke when you let off, but you just dont see it? Sounds like you need valve seals (and possibly guides), my friend.
D/W
If it ain't broke, fix it!
