| no smoke https://slantsix.org/forum/viewtopic.php?t=12496 |
| Author: | moparfiend [ Mon Apr 04, 2005 12:52 am ] |
| Post subject: | no smoke |
have 2 cylinders that are oil fouling the plugs. what i don't understand is, at no time does the engine smoke. shouldn't it smoke as the plugs are beginning to foul? compression is 145 lbs give or take 5 lbs all cyl. |
| Author: | Dennis Weaver [ Mon Apr 04, 2005 4:23 am ] |
| Post subject: | Re: no smoke |
Quote: have 2 cylinders that are oil fouling the plugs. what i don't understand is, at no time does the engine smoke. shouldn't it smoke as the plugs are beginning to foul? compression is 145 lbs give or take 5 lbs all cyl.
Sure it doesn't smoke when you let off, but you just dont see it? Sounds like you need valve seals (and possibly guides), my friend.D/W |
