| EFI stock slant six https://slantsix.org/forum/viewtopic.php?t=12535 |
Page 1 of 2 |
| Author: | voiceofstl [ Wed Apr 06, 2005 11:38 pm ] |
| Post subject: | EFI stock slant six |
Mopar made rear wheel drive cars till 1989? Were any of these slant 6's with efi??????? I know I saw a late 80's RWD with a efi 318 in it. |
| Author: | Dart270 [ Thu Apr 07, 2005 12:20 am ] |
No. Lou |
| Author: | Charrlie_S [ Thu Apr 07, 2005 6:19 am ] |
| Post subject: | Re: EFI stock slant six |
Quote: Mopar made rear wheel drive cars till 1989?
As far as I know the only efi 318's were in trucks. I have a 88 diplomat, and it is a 318 with lean burn and carb. 1989 was the last year for these cars, and I think the engine setup was the same.
| Author: | Slant6Ram [ Thu Apr 07, 2005 6:24 am ] |
| Post subject: | Don't we wish |
There was never a factory produced EFI for any of the slant six family. It's rumored that chrysler did the research but never put it into production. It's custom fabrication to get EFI. A couple of guys have it working (I think) Do a search for megasquirt to find them. |
| Author: | voiceofstl [ Thu Apr 07, 2005 6:57 am ] |
Quote: Quote: Mopar made rear wheel drive cars till 1989?
As far as I know the only efi 318's were in trucks. I have a 88 diplomat, and it is a 318 with lean burn and carb. 1989 was the last year for these cars, and I think the engine setup was the same.Were any of these slant 6's with efi??????? I know I saw a late 80's RWD with a efi 318 in it. |
| Author: | 440_Magnum [ Thu Apr 07, 2005 7:13 am ] |
The last M-body was the 1989 Diplomat/Gran Fury/Fifth Avenue. The only engine available was a feedback-carbureted 2-bbl 318 (albeit with roller cam and nice fast-burn heads).Were any of these slant 6's with efi??????? I know I saw a late 80's RWD with a efi 318 in it. There was a throttle-body EFI *TRUCK* 318 offered in '89, but not in cars. You may have seen a transplanted truck engine in an M-body. With Chrysler, I'll never say "absolutely never," but if there were any EFI 89 M-bodies built at the factory, it would have only been for R&D. Well, I will say "never" on one thing: there were never any factory-built EFI sl6 cars. The last SL6 car was the 83 M-body. |
| Author: | Charrlie_S [ Thu Apr 07, 2005 7:14 am ] |
I need to correct myself. I don't think the 89 car 318's were efi (need to check), but Chrysler did have a fuel injected 318 in the Imperial, forget what year, but had quite a few problems, and most were converted to carbs. |
| Author: | 440_Magnum [ Thu Apr 07, 2005 7:50 am ] |
Quote: I need to correct myself. I don't think the 89 car 318's were efi (need to check), but Chrysler did have a fuel injected 318 in the Imperial, forget what year, but had quite a few problems, and most were converted to carbs.
The EFI Imperial was built from 81-83. Those cars are actually getting semi-collectible now. I used to know a guy who owned 3, all with the original EFI system still working- this was in about 1998.http://teamchicago.com/imperial/underfi2.jpg As you can see, it looks almost identical to an 81-89 carbureted 318. The only visual clue (apart from the words on the air cleaner) is the air-flow sensor in the air cleaner snorkel. Even the computer box on the side of the air cleaner looks almost exactly like the feedback computer for a carbureted 318. Here are a lot of pictures of what the car looked like: http://www.imperialclub.com/Yr/1981/SpottersGuide/ |
| Author: | Dennis Weaver [ Thu Apr 07, 2005 8:05 am ] |
...Chrysler Corp. actually offered EFI on the '57 DeSoto. D/W |
| Author: | 440_Magnum [ Thu Apr 07, 2005 8:25 am ] |
Quote: ...Chrysler Corp. actually offered EFI on the '57 DeSoto.
And the 58 300D D/W |
| Author: | Dennis Weaver [ Thu Apr 07, 2005 8:35 am ] |
...let's see if we can find some pictures. I think they had a trunk full of fifties-era tube electronics, didn't they? D/W |
| Author: | Charrlie_S [ Thu Apr 07, 2005 9:28 am ] |
On the 57 and 58 Mopars, was the fuel injection EFI, or mechanical, ala rochester, on the GM cars. |
| Author: | 440_Magnum [ Thu Apr 07, 2005 10:03 am ] |
Quote: ...let's see if we can find some pictures. I think they had a trunk full of fifties-era tube electronics, didn't they?
D/W Nah, it was a Bendix mechanical system, similar to the Rochester mechanical system on "fuelie" Corvettes. From what I hear, the Rochester system actually worked better. |
| Author: | Dennis Weaver [ Thu Apr 07, 2005 10:35 am ] |
Quote: Quote: ...let's see if we can find some pictures. I think they had a trunk full of fifties-era tube electronics, didn't they?
D/W Nah, it was a Bendix mechanical system, similar to the Rochester mechanical system on "fuelie" Corvettes. From what I hear, the Rochester system actually worked better. D/W |
| Author: | Super6 [ Thu Apr 07, 2005 10:52 am ] |
In regards to trucks: In '88 318's went TBI In '89 360's went TBI Not sure on the V6's. |
| Page 1 of 2 | All times are UTC-07:00 |
