It is currently Wed Jun 24, 2026 3:16 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
 Post subject: EFI stock slant six
PostPosted: Wed Apr 06, 2005 11:38 pm
Mopar made rear wheel drive cars till 1989?
Were any of these slant 6's with efi???????
I know I saw a late 80's RWD with a efi 318 in it.
PostPosted: Thu Apr 07, 2005 12:20 am
No.
 Post subject: Re: EFI stock slant six
PostPosted: Thu Apr 07, 2005 6:19 am
As far as I know the only efi 318's were in trucks. I have a 88 diplomat, and it is a 318 with lean burn and carb. 1989 was the last year for these cars, and I think the engine setup was the same.
 Post subject: Don't we wish
PostPosted: Thu Apr 07, 2005 6:24 am
There was never a factory produced EFI for any of the slant six family. It's rumored that chrysler did the research but never put it into production.
It's custom fabrication to get EFI. A couple of guys have it working (I think)
Do a search for megasquirt to find them.
1980 Aspen 225 super six
PostPosted: Thu Apr 07, 2005 6:57 am
I'm sure I saw a 1989 5th ave. with a efi 318 in it.
PostPosted: Thu Apr 07, 2005 7:13 am
The last M-body was the 1989 Diplomat/Gran Fury/Fifth Avenue. The only engine available was a feedback-carbureted 2-bbl 318 (albeit with roller cam and nice fast-burn heads).
There was a throttle-body EFI *TRUCK* 318 offered in '89, but not in cars. You may have seen a transplanted truck engine in an M-body. With Chrysler, I'll never say "absolutely never," but if there were any EFI 89 M-bodies built at the factory, it would have only been for R&D.
Well, I will say "never" on one thing: there were never any factory-built EFI sl6 cars. The last SL6 car was the 83 M-body.
PostPosted: Thu Apr 07, 2005 7:14 am
I need to correct myself. I don't think the 89 car 318's were efi (need to check), but Chrysler did have a fuel injected 318 in the Imperial, forget what year, but had quite a few problems, and most were converted to carbs.
PostPosted: Thu Apr 07, 2005 7:50 am
The EFI Imperial was built from 81-83. Those cars are actually getting semi-collectible now. I used to know a guy who owned 3, all with the original EFI system still working- this was in about 1998.
http://teamchicago.com/imperial/underfi2.jpg
As you can see, it looks almost identical to an 81-89 carbureted 318. The only visual clue (apart from the words on the air cleaner) is the air-flow sensor in the air cleaner snorkel. Even the computer box on the side of the air cleaner looks almost exactly like the feedback computer for a carbureted 318.
Here are a lot of pictures of what the car looked like:
http://www.imperialclub.com/Yr/1981/SpottersGuide/
PostPosted: Thu Apr 07, 2005 8:05 am
...Chrysler Corp. actually offered EFI on the '57 DeSoto. :shock:
D/W
If it ain't broke, fix it!
PostPosted: Thu Apr 07, 2005 8:25 am
D/W
And the 58 300D :D
PostPosted: Thu Apr 07, 2005 8:35 am
...let's see if we can find some pictures. I think they had a trunk full of fifties-era tube electronics, didn't they?
D/W
PostPosted: Thu Apr 07, 2005 9:28 am
On the 57 and 58 Mopars, was the fuel injection EFI, or mechanical, ala rochester, on the GM cars.
PostPosted: Thu Apr 07, 2005 10:03 am
D/W
Nah, it was a Bendix mechanical system, similar to the Rochester mechanical system on "fuelie" Corvettes.
From what I hear, the Rochester system actually worked better.
PostPosted: Thu Apr 07, 2005 10:35 am
D/W
You sure about that? I'm pretty sure it was electronic, but I've only ever seen pictures.
D/W
PostPosted: Thu Apr 07, 2005 10:52 am
In regards to trucks:
In '88 318's went TBI
In '89 360's went TBI
Not sure on the V6's.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 10 guests
